Tado integration - Add Support for tado X devices
I understand the release notes that they are adding some parts to the beta releases bit by bit so that they can test them more specifically.
Only when the tado entry is included can it also be tested in the beta.
Hi, to clear things up here: I only bumped the dependency in this PR (as it is policy in HA core to bump dependencies seperately from feature PRs). This got merged.
The actual PR with the quick fix got closed, because there was a blocking review only hours before the beta cut with unfortunately no way to get it fixed in time. Unfortunately, the PR layed around for three weeks prior with no further review, and only got pushed back in the last minute.
That is why it was decided to close the PR and continue work on the all-new integration with proper Tado X support, as it would not have made sense to wait another full month for the patched old integration to be released, when hopefully, in this time the new integration may be available (no promises here, though).
For those wanting to use Tado X right now: Here are the steps to get the patched integration out of the PR and use it on your local HA installation Support for TadoX thermostatic radiator valves by Moritz-Schmidt · Pull Request #129600 · home-assistant/core · GitHub (please copy the files from hass-core/homeassistant/components/tado at dev · Moritz-Schmidt/hass-core · GitHub here instead of the link in the comment, there was a mistake)
Judging from the Matter 1.4 standard, it should be in the Matter protocol. No idea though, if tado and/or HA have it implemented correctly.
There’s a typo in the PR comment.
Files must be copied from
Unfortunately, because the bot locked the PR, it is not possible to edit the comment anymore. I noted it above, thanks for pointing it out!
Ah that makes a difference! Great, now I can have my office temperature set again based on whether I work from home or not :slight_smile: Love it! :heart:
Any chance we could have this all-new integration in some way with eg. HACS? Little is better than nothing and we can get ahead of the switch (not like the old integration helps us anyways with tado x, so might aswell)
Unfortunately you were right and with 2024.12 there was no innovation for the tado X devices.
But the custom integration works perfectly with the tado X devices even under HA 2024.12!
edit:
Do any of you use the HACS integration Better Thermostats with the tado devices?
If so, how did you set the configuration so that it reactivates auto mode after closing the window?
This somehow doesn’t work correctly in my tests.
The patched integration works reasonably and is certainly a step in the right direction, but I find that if settings are changed via the Tado app then this is not reflected in HA. In general, things are not always being updated, for example the heating status doesn’t change when heating stops.
Any news on the status of the all-new Tado X integration?
Thanks. Can someone explain in few simple words how I can copy these files ? I can’t see any download button. And how to upload these files in Home Assistant ?
I did copy the files in the folder, but i don’t know how to create the manifest.json and how it would look like. Can you share the file please?
If you paste the github folder url on this site, then you can download the files.
If the manifest file is not in the folder you have the wrong one. Read the post carefully
Thank you very much :heart:
I finally achieved to copy the files and it works. I can now control the HOME/AWAY setting and the AUTO control mode directly with HA :slight_smile:
I’ve just got this working with the EU version of the receiver X + 6x TRVS + Viessman 050-w B0KA combo boiler (opentherm mode)
Compared to the wiser setup I had , the tado seems to prefer much lower flow temps. Is that normal/does it perform some form of flow calibration during the first few hours of use?
Do I have to copy everything from this site, including the textures folder to the newly created “tado” folder?
wrong folder. this one. hass-core/homeassistant/components/tado at dev · Moritz-Schmidt/hass-core · GitHub
Use this to download the above URL easier. https://download-directory.github.io/
If you look closely, I already mentioned it here
Hi - thanks for the custom integration of tado x devices! I’ve a basic question: have downloaded the files, copied them to the custom_integration folder under “tado” and also restarted HA … but nothing happened. Still have my old Tado integration there (and working) but no tado x support. Tried also to deinstall tado before and then restarted, but same result. May I ask for your support? Thx
Did you make the changes to m’n manifest.json?
