Tado Integration - Put Offset
I’ve tried this out for a while, but the re-calibration on every offset update is a real pain - noise wise.
Has anyone tried using the tado API and a template switch to create a switch that turns the radiator on and off (e.g. set to off or heat (with high temp) and then use the temperature sensor and this template switch to create a generic thermostat?
