Hi Team. I was wondering if anyone can make or can make suggestions on how to make this flow easier on the eye or more efficient.
The flow will do the following
- check to see if my Mrs or myself are home. If we are
- If we are is there an open window open. If there is turn the heating in that room off
- If no open window are we overriding the heating to turn it off for 60 minues. If we are turn off
- If we are not overriding the heating are we wanting to boost the heating to 25 degrees. If we are boost of 60 minutes then turn the boost boolean to off.,
- If we are not boosting. Is there temp in the room => 21 degrees.
- If it is , is the time between 5am and 9PM at night.
- If it is , is Craig working from home? If I am turn the heating in that room off.
- If Craig is not WFH set the temp to heat up to 21
- pretty much the same for Saturday and Sunday routine
- when the reading reaches 21 turn it off in that room
Then there is a section to turn the heating off if my Mrs and I are not home,
[{"id":"172a1b8c897e3391","type":"tab","label":"Tado Schedules","disabled":false,"info":"","env":[]},{"id":"616dca7f1eba2cdc","type":"group","z":"172a1b8c897e3391","name":"Livingroom Temprature","style":{"label":true,"stroke":"#ffff3f"},"nodes":["4e082d773ac30ba3","cb0ddb687f15bca1","29b6c95794a689c5","b9231a25c6073d80","655e8d042a562dc8","fc8d492dddf5f364","e8552963317e863f","08d7bad3b19dbc05","2eb32022990c0446","e6acd9b759a3ec49","98606482b7e6886c","a31b8c5921c077f2","e8fa825c28a14aef","309b7c6ac3c30164","1f4a75c54a4a84db","8e2ae227322c26af","9012cec5c5bd6032","de6ce8dc14655cf0","31567fbe9ee40db7","758f4358680306aa","975459d7a492de95","50ad4f4b149e9a8a","484a7257584fb564","e674b15df777d335","5f4bed738dc6d313","5483336e87024d21","0a20bad0ccd7cf68","e6418e8e3b655502","b2bbdbd4694f55ae","db7ea77ad5b4ac25","0c391e39dec03bdf","a0b5bb1f5c6f4419","d93915df5a1f5cc6","c26e69d6c76b8165","cc564a04956c6993","248d1936fc68984a","7583cacb709e2e48","f559f0186569506d"],"x":14,"y":19,"w":1812,"h":822},{"id":"0c391e39dec03bdf","type":"junction","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","x":740,"y":380,"wires":[["655e8d042a562dc8","29b6c95794a689c5"]]},{"id":"4e082d773ac30ba3","type":"api-call-service","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Livingroom Temprature - ON","server":"fe0fc272.cbcc2","version":5,"debugenabled":false,"domain":"climate","service":"turn_on","areaId":[],"deviceId":[],"entityId":["climate.livingroom_temperature"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1280,"y":440,"wires":[["d93915df5a1f5cc6"]]},{"id":"cb0ddb687f15bca1","type":"api-call-service","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Livingroom Temprature - OFF","server":"fe0fc272.cbcc2","version":5,"debugenabled":false,"domain":"climate","service":"turn_off","areaId":[],"deviceId":[],"entityId":["climate.livingroom_temperature"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1290,"y":340,"wires":[[]]},{"id":"29b6c95794a689c5","type":"within-time-switch","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"","nameInt":"","positionConfig":"6d1d5c66bea34100","startTime":"05:00","startTimeType":"entered","startOffset":0,"startOffsetType":"none","startOffsetMultiplier":60000,"endTime":"21:00","endTimeType":"entered","endOffset":0,"endOffsetType":"none","endOffsetMultiplier":60000,"timeRestrictions":0,"timeRestrictionsType":"none","timeDays":"1,2,3,4,5","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeOnlyOddWeeks":false,"timeOnlyEvenWeeks":false,"timeMonths":"*","timedatestart":"","timedateend":"","propertyStart":"","propertyStartType":"none","propertyStartCompare":"true","propertyStartThreshold":"","propertyStartThresholdType":"num","startTimeAlt":"","startTimeAltType":"entered","startOffsetAlt":0,"startOffsetAltType":"none","startOffsetAltMultiplier":60000,"propertyEnd":"","propertyEndType":"none","propertyEndCompare":"true","propertyEndThreshold":"","propertyEndThresholdType":"num","endTimeAlt":"","endTimeAltType":"entered","endOffsetAlt":0,"endOffsetAltType":"none","endOffsetAltMultiplier":60000,"withinTimeValue":"true","withinTimeValueType":"msgInput","outOfTimeValue":"false","outOfTimeValueType":"msgInput","tsCompare":"0","x":850,"y":380,"wires":[["b9231a25c6073d80"],[]]},{"id":"b9231a25c6073d80","type":"api-current-state","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Craig WFH?","server":"fe0fc272.cbcc2","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.mode_craig_wfh","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1050,"y":380,"wires":[["cb0ddb687f15bca1"],["4e082d773ac30ba3"]]},{"id":"655e8d042a562dc8","type":"within-time-switch","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"","nameInt":"","positionConfig":"6d1d5c66bea34100","startTime":"05:00","startTimeType":"entered","startOffset":0,"startOffsetType":"none","startOffsetMultiplier":60000,"endTime":"21:00","endTimeType":"entered","endOffset":0,"endOffsetType":"none","endOffsetMultiplier":60000,"timeRestrictions":0,"timeRestrictionsType":"none","timeDays":"6,0","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeOnlyOddWeeks":false,"timeOnlyEvenWeeks":false,"timeMonths":"*","timedatestart":"","timedateend":"","propertyStart":"","propertyStartType":"none","propertyStartCompare":"true","propertyStartThreshold":"","propertyStartThresholdType":"num","startTimeAlt":"","startTimeAltType":"entered","startOffsetAlt":0,"startOffsetAltType":"none","startOffsetAltMultiplier":60000,"propertyEnd":"","propertyEndType":"none","propertyEndCompare":"true","propertyEndThreshold":"","propertyEndThresholdType":"num","endTimeAlt":"","endTimeAltType":"entered","endOffsetAlt":0,"endOffsetAltType":"none","endOffsetAltMultiplier":60000,"withinTimeValue":"true","withinTimeValueType":"msgInput","outOfTimeValue":"false","outOfTimeValueType":"msgInput","tsCompare":"0","x":850,"y":520,"wires":[["e8552963317e863f"],["50ad4f4b149e9a8a"]]},{"id":"fc8d492dddf5f364","type":"api-call-service","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Livingroom Temprature - OFF","server":"fe0fc272.cbcc2","version":5,"debugenabled":false,"domain":"climate","service":"turn_off","areaId":[],"deviceId":[],"entityId":["climate.livingroom_temperature"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1030,"y":800,"wires":[[]]},{"id":"e8552963317e863f","type":"api-call-service","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Livingroom Temprature - ON","server":"fe0fc272.cbcc2","version":5,"debugenabled":false,"domain":"climate","service":"turn_on","areaId":[],"deviceId":[],"entityId":["climate.livingroom_temperature"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1120,"y":520,"wires":[["a0b5bb1f5c6f4419"]]},{"id":"08d7bad3b19dbc05","type":"api-current-state","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Livingroom Temprature Source","server":"fe0fc272.cbcc2","version":3,"outputs":2,"halt_if":"21","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.livingroom_temperature_current_temperature","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":570,"y":400,"wires":[["0c391e39dec03bdf"],["c26e69d6c76b8165"]]},{"id":"2eb32022990c0446","type":"inject","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"60","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":130,"y":100,"wires":[["de6ce8dc14655cf0"]]},{"id":"e6acd9b759a3ec49","type":"inject","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"300","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":680,"wires":[["309b7c6ac3c30164"]]},{"id":"98606482b7e6886c","type":"api-current-state","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Livingroom Temprature Source","server":"fe0fc272.cbcc2","version":3,"outputs":2,"halt_if":"21","halt_if_type":"num","halt_if_compare":"gte","entity_id":"sensor.livingroom_temperature_current_temperature","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":730,"y":800,"wires":[["fc8d492dddf5f364"],[]]},{"id":"a31b8c5921c077f2","type":"comment","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Monday - Friday","info":"","x":860,"y":340,"wires":[]},{"id":"e8fa825c28a14aef","type":"comment","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Saturday - Sunday","info":"","x":870,"y":480,"wires":[]},{"id":"1f4a75c54a4a84db","type":"api-current-state","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Craig - Not_Home","server":"fe0fc272.cbcc2","version":3,"outputs":2,"halt_if":"not_home","halt_if_type":"str","halt_if_compare":"is","entity_id":"device_tracker.craigs_iphone","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":550,"y":640,"wires":[["9012cec5c5bd6032"],[]]},{"id":"8e2ae227322c26af","type":"api-current-state","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Lizzie - Not_Home","server":"fe0fc272.cbcc2","version":3,"outputs":2,"halt_if":"not_home","halt_if_type":"str","halt_if_compare":"is","entity_id":"device_tracker.lizzie_iphone","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":550,"y":720,"wires":[["9012cec5c5bd6032"],[]]},{"id":"9012cec5c5bd6032","type":"change","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"not_home","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":680,"wires":[["98606482b7e6886c"]]},{"id":"309b7c6ac3c30164","type":"change","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":680,"wires":[["1f4a75c54a4a84db","8e2ae227322c26af"]]},{"id":"de6ce8dc14655cf0","type":"change","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":100,"wires":[["31567fbe9ee40db7","758f4358680306aa"]]},{"id":"31567fbe9ee40db7","type":"api-current-state","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Craig - Home","server":"fe0fc272.cbcc2","version":3,"outputs":2,"halt_if":"home","halt_if_type":"str","halt_if_compare":"is","entity_id":"device_tracker.craigs_iphone","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":500,"y":60,"wires":[["975459d7a492de95"],[]]},{"id":"758f4358680306aa","type":"api-current-state","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Lizzie - Home","server":"fe0fc272.cbcc2","version":3,"outputs":2,"halt_if":"home","halt_if_type":"str","halt_if_compare":"is","entity_id":"device_tracker.lizzie_iphone","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":500,"y":140,"wires":[["975459d7a492de95"],[]]},{"id":"975459d7a492de95","type":"change","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"home","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":680,"y":100,"wires":[["7583cacb709e2e48"]]},{"id":"50ad4f4b149e9a8a","type":"api-call-service","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Livingroom Temprature - OFF","server":"fe0fc272.cbcc2","version":5,"debugenabled":false,"domain":"climate","service":"turn_off","areaId":[],"deviceId":[],"entityId":["climate.livingroom_temperature"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1130,"y":580,"wires":[[]]},{"id":"484a7257584fb564","type":"api-current-state","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Override Livingroom Heating - Boost ON","server":"fe0fc272.cbcc2","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.tado_livingroom_heating_boost","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":220,"y":300,"wires":[["b2bbdbd4694f55ae"],["08d7bad3b19dbc05"]]},{"id":"e674b15df777d335","type":"api-current-state","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Override Livingroom Heating - Turn ON","server":"fe0fc272.cbcc2","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.tado_livingroom_heating_off","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1200,"y":120,"wires":[["5f4bed738dc6d313"],["484a7257584fb564"]]},{"id":"5f4bed738dc6d313","type":"api-call-service","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Livingroom Temprature - OFF","server":"fe0fc272.cbcc2","version":5,"debugenabled":false,"domain":"climate","service":"turn_off","areaId":[],"deviceId":[],"entityId":["climate.livingroom_temperature"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":190,"y":200,"wires":[["cc564a04956c6993"]]},{"id":"5483336e87024d21","type":"api-call-service","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Set Livingroom Temprature - Boost 25","server":"fe0fc272.cbcc2","version":5,"debugenabled":false,"domain":"climate","service":"set_temperature","areaId":[],"deviceId":[],"entityId":["climate.livingroom_temperature"],"data":"{\"temperature\":25}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":850,"y":260,"wires":[["0a20bad0ccd7cf68"]]},{"id":"0a20bad0ccd7cf68","type":"trigger","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"60 Minute Timer","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"60","extend":false,"overrideDelay":false,"units":"min","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":1100,"y":260,"wires":[["db7ea77ad5b4ac25"]]},{"id":"e6418e8e3b655502","type":"api-call-service","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Override Livingroom Heating - Boost OFF","server":"fe0fc272.cbcc2","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.tado_livingroom_heating_boost"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1640,"y":260,"wires":[[]]},{"id":"b2bbdbd4694f55ae","type":"api-call-service","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Livingroom Temprature - ON","server":"fe0fc272.cbcc2","version":5,"debugenabled":false,"domain":"climate","service":"turn_on","areaId":[],"deviceId":[],"entityId":["climate.livingroom_temperature"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":560,"y":260,"wires":[["5483336e87024d21"]]},{"id":"db7ea77ad5b4ac25","type":"api-call-service","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Livingroom Temprature - OFF","server":"fe0fc272.cbcc2","version":5,"debugenabled":false,"domain":"climate","service":"turn_off","areaId":[],"deviceId":[],"entityId":["climate.livingroom_temperature"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1330,"y":260,"wires":[["e6418e8e3b655502"]]},{"id":"a0b5bb1f5c6f4419","type":"api-call-service","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Set Livingroom Temprature - Boost 21","server":"fe0fc272.cbcc2","version":5,"debugenabled":false,"domain":"climate","service":"set_temperature","areaId":[],"deviceId":[],"entityId":["climate.livingroom_temperature"],"data":"{\"temperature\":21}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1430,"y":520,"wires":[[]]},{"id":"d93915df5a1f5cc6","type":"api-call-service","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Set Livingroom Temprature - 21","server":"fe0fc272.cbcc2","version":5,"debugenabled":false,"domain":"climate","service":"set_temperature","areaId":[],"deviceId":[],"entityId":["climate.livingroom_temperature"],"data":"{\"temperature\":21}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1570,"y":440,"wires":[[]]},{"id":"c26e69d6c76b8165","type":"api-call-service","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Livingroom Temprature - OFF","server":"fe0fc272.cbcc2","version":5,"debugenabled":false,"domain":"climate","service":"turn_off","areaId":[],"deviceId":[],"entityId":["climate.livingroom_temperature"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":570,"y":480,"wires":[[]]},{"id":"cc564a04956c6993","type":"trigger","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"60 Minute Timer","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"60","extend":false,"overrideDelay":false,"units":"min","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":440,"y":200,"wires":[["248d1936fc68984a"]]},{"id":"248d1936fc68984a","type":"api-call-service","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Override Livingroom Heating - Turn OFF","server":"fe0fc272.cbcc2","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.tado_livingroom_heating_off"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":700,"y":200,"wires":[[]]},{"id":"7583cacb709e2e48","type":"api-current-state","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Open Window Detection","server":"fe0fc272.cbcc2","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.livingroom_tuya_window_sensor_contact","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":890,"y":60,"wires":[["f559f0186569506d"],["e674b15df777d335"]]},{"id":"f559f0186569506d","type":"api-call-service","z":"172a1b8c897e3391","g":"616dca7f1eba2cdc","name":"Livingroom Temprature - OFF","server":"fe0fc272.cbcc2","version":5,"debugenabled":false,"domain":"climate","service":"turn_off","areaId":[],"deviceId":[],"entityId":["climate.livingroom_temperature"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1170,"y":60,"wires":[[]]},{"id":"fe0fc272.cbcc2","type":"server","name":"McHome Assistant","addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"","statusSeparator":"","enableGlobalContextStore":false},{"id":"6d1d5c66bea34100","type":"position-config","name":"","isValide":"true","angleType":"deg","timeZoneOffset":99,"timeZoneDST":0,"stateTimeFormat":"3","stateDateFormat":"12","contextStore":""}]
