Tado is not working anymore in 0,61. I get the following error:
Error while setting up platform tado
File “/usr/lib/python3.6/urllib/request.py”, line 1318, in do_open
encode_chunked=req.has_header(‘Transfer-encoding’))
File “/usr/lib/python3.6/http/client.py”, line 1239, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/lib/python3.6/http/client.py”, line 1285, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/lib/python3.6/http/client.py”, line 1234, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/lib/python3.6/http/client.py”, line 1026, in _send_output
self.send(msg)
File “/usr/lib/python3.6/http/client.py”, line 964, in send
self.connect()
File “/usr/lib/python3.6/http/client.py”, line 1392, in connect
super().connect()
File “/usr/lib/python3.6/http/client.py”, line 936, in connect
(self.host,self.port), self.timeout, self.source_address)
File “/usr/lib/python3.6/socket.py”, line 704, in create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
File “/usr/lib/python3.6/socket.py”, line 745, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File “/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py”, line 171, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File “/usr/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 245, in result
raise self._exception
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/lib/python3.6/site-packages/homeassistant/components/sensor/tado.py”, line 32, in setup_platform
zones = tado.get_zones()
File “/usr/lib/python3.6/site-packages/homeassistant/components/tado.py”, line 110, in get_zones
return self.tado.getZones()
File “/usr/lib/python3.6/site-packages/PyTado/interface.py”, line 189, in getZones
data = self._apiCall(cmd)
File “/usr/lib/python3.6/site-packages/PyTado/interface.py”, line 81, in _apiCall
response = self.opener.open(req)
File “/usr/lib/python3.6/urllib/request.py”, line 526, in open
response = self._open(req, data)
File “/usr/lib/python3.6/urllib/request.py”, line 544, in _open
‘_open’, req)
File “/usr/lib/python3.6/urllib/request.py”, line 504, in _call_chain
result = func(*args)
File “/usr/lib/python3.6/urllib/request.py”, line 1361, in https_open
context=self._context, check_hostname=self._check_hostname)
File “/usr/lib/python3.6/urllib/request.py”, line 1320, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [Errno -3] Try again>
Is there a solution to this problem?
Kinds regards.
Milan
