Tado: Obtain current set/target temperature (for ondemand/boost)
I am trying to work out how to get the target/set temperature for my Tado system.
The climate.room.attributes.temperature value would appear to be what I want, however it seems to be the scheduled temperature and not the actual set/target temperature in situations where you manually increase/boost the temperature.
I think I’m wanting something which is a limitation of the integration (although the data seems readily available on my.tado.com).
Anyone got a solution here?
