Currently in the process of moving to HomeAssistant after running on Smartthings for the last couple of years. The extra possibilities seem brilliant but I’m having trouble trying to get the Tado presence detection to work.
I’ve installed the normal Tado integration through the GUI and have added the Tado presence detection code to the YAML file but nowhere is the presence sensor showing up.
I thought you only had to fill in the home ID if you had multiple homes under your login. As I’ve just got one I want all the presence devices to come across.
So i’ve just gone to find my home ID by going to the website on the Tado integration page and changing the username and password only to get the below message.
Now i know my details are correct as I can use them to log in to tado on the website. Do the username and password need to be in an quotation brackets or something like that at all?
This might explain the 401 error that I’m getting without the home ID
I would love to go the opposite route and setup an existing device tracker from my router to set tado presence. What is the smartest way to achieve that?
E.g. if no one is logged into our Wifi set tado to away mode.
My fallback plan would be to write an automation sending requests to the tado api based on presence changes.
