TADO valves without cloud
I have a good offer for a set of TADO radiator valves. Can these valves work without internet and cloud and if yes, using which integration? I have a deCONZ/Conbee II Zigbee stick.
They are supposed to to work with the Homekit integration.
Do I need any hardware for the Homekit integration, or only TADO valves?
Which HA integrations should I install for TADO ?
@tatarin Did you manage to connect TADO valves with HA without the bridge?
I did not buy them yet. Still unclear if only valves are enough, or I have to purchase also some hardware bridge, to connect them with HA.
I did buy them but only after I realised that I need the bridge… I was hoping someone found out a way to skip the bridge but doesn’t seem so… probably Eve is better for you since it doesn’t need the bridge according to apple website that says it is compatible with homekit without bridge/gateway
