Tado via Homekit Controller, no hvac_mode auto
Hi all,
I’m quite new to HA. I added my Tado thermostat via Homekit Controller. All works well however I can only turn the heating on and off, can’t switch over back to auto mode. I can as hvac_mode only select ‘off’ and heat (see below). Is there a way how I can solve this?
hvac_modes:
  - 'off'
  - heat
min_temp: 5
max_temp: 25
current_temperature: 19.6
temperature: 20
current_humidity: 44
hvac_action: idle
friendly_name: Thermostat Living
supported_features: 1
Thanks!
Did you figure this out? I’m guessing off means auto and heat means manual (or maybe the opposite)?
It not possible. The Homekit is control Tado locally. the Auto mode program is stored in the cloud. Not possible to access it locally.
