Team,
I need your help.
I have moved to Tado X and is a little a nightmare, nothing appear to work.
It took me more than 5 hour to have the bridge, Smart thermostat and Smart Valves connected and working.
I’ve done all of it with the Tado App.
I’ve found the Device Linking with the Matter icon :). Yesterday it was not working, today it generates the code.
As per instructions I’ve generated the code of the Smart Valve I want to add and then opened the Home Assistant Companion → Integration/Devices → Devices → Add device → Add Matter Device → Yes It’s already in use → Other Controller → Paste the Device Linking Code in the Setup Code field → Done → Add Device
I get the Adding the Device, this may take a minute or two
and then…
Failed to Add the Device
With no explanation nor how can I fix it
Can anyone help?
