Tado X - Matter not able to connect
Hi everyone,
I’m new to the Home Assistant topic and, thanks to the Black Friday deals, I’ve decided to make my home a bit “smarter.”
I’ve now set up a fresh installation of Home Assistant and want to integrate my Tado X thermostats. However, I’m running into an error when trying to add the thermostat to my environment: “Device cannot be added.”
Here’s what my setup looks like:
  • Tado Smart Radiator Thermostat X
  • Sonoff Zigbee 3.0 USB Dongle Plus-E: “MultiPAN RCP” firmware
  • With the following add-ons:
  1. Silicon Labs Multiprotocol
  2. Mosquitto broker
  3. Zigbee2MQTT
  4. Matter Server (6.6.1)
  5. Open Thread Border Router
The connection to Zigbee devices like my Hue lamps works without any issues. However, when I try to add the thermostat via the Home Assistant app and enter the Matter code, it takes some time, but eventually, I get the following error:
I’m not getting any useful logs from either the Matter Server or any other sources to help me track down the problem.
I have already read that issues can arise when using Multipan/Multiprotocol. However, since I’m new to this whole topic and don’t have too many devices yet, I thought I could save some money and use a single stick for both purposes for now, with the option to upgrade to a second stick later if needed.
I appreciate your help and am curious to see how this unfolds. :slight_smile:
Feel free to reach out if you need any more information!
Thank you!
Luca
