Since the Tado X wireless thermostats are very expensive i have bought a few Aqara Temperature sensors. Tado is connected to HA using Matter and the Aqara temp sensor with Zigbee2mqtt. I want the Tado TRV to use the temp sensor for the temp (obviously). I have found a blueprint online for ‘Tado temperature offset’ which uses the offset to dynamically change but this was made for the V3, not the X so it doesn’t work. Since i am new to HA i am asking here for help… how do i do this?
I could use Better Thermostat but i want to keep using the Tado app and i believe i cant use the app aymore if i use Better thermostat
