I’ve seen some asking about getting tag scanned data. Here is what I did in order to map the tag_id to the name of the tag. I use linux with python venv, so modifications may be needed.
Create a python script…
tags.py
#! /srv/homeassistant/bin/python3
import json
new_tags = {}
new_tags['data'] = {}
with open('.storage/tag', 'r') as f:
tags = json.load(f)
tag_data = tags['data']['items']
for tag in tag_data:
t = tag.pop('tag_id')
d = tag
new_tags['data'][t] = d
print(json.dumps(new_tags))
Create a command_line sensor…
- sensor:
command: "python3 /home/homeassistant/.homeassistant/./tags.py"
scan_interval: 10
json_attributes:
- data
value_template: '-'
What you get…
sensor.tags
501404bf-fa3c-4d9c-b217-1178dbd46a1d:
last_scanned: '2023-10-24T21:05:14.416925+00:00'
04-C0-38-73-CF-61-80:
last_scanned: '2023-10-24T21:07:20.009623+00:00'
c94a7b32-7e92-4eeb-a27d-e0dcd4e7494a:
last_scanned: '2023-10-24T21:06:09.166335+00:00'
Now in an automation…
platform: event
event_type: tag_scanned
variables:
# get the tag_id of the scanned tag
id: "{{ trigger.event.data.tag_id }}"
# use the id to look up the name by id in sensor.tags
tag_name: "{{ state_attr('sensor.tags', 'data')[ id ][ 'name' ] }}"
# need the device_id of the device that scanned the card?
dev_id: "{{ trigger.event.data.device_id }}"
- service: script.tags
tag_name: "{{ tag_name }}"
dev_id: "{{ dev_id }}"
Hope this helps someone out! If someone thinks of a way to improve this or a better way… please share!
