Tagesschau in 100 Seconds as MP3 or MP4 in Home Assistant
There are very few up-to-date guides on how to use Tagesschau in 100 Sekunden in Home Assistant.
Most existing posts are outdated and no longer work, mainly because URLs and feeds have changed.
This post shows a simple and working approach to make Tagesschau in 100 Sekunden available as MP3 and MP4 — without downloading anything.
What is “Tagesschau in 100 Sekunden”?
Tagesschau in 100 Sekunden is a daily German news summary by ARD.
It is published as:
  • Audio (MP3) – ideal for Sonos or smart speakers
  • Video (MP4) – ideal for tablets or wall-mounted displays
The important part:
:backhand_index_pointing_right: The official podcast feeds already contain direct media URLs.
Important notes
  • You must be online to use this solution
  • Nothing is downloaded
  • The media URL is extracted and played directly
  • The URL changes multiple times per day, with every new episode
  • Home Assistant always fetches the current link from the feed
This is exactly why older hard-coded links no longer work.
Why not use the Feedreader integration?
Home Assistant’s feedreader integration:
  • does not expose the enclosure URLs
  • only provides title, description, and HTML links
So we read the podcast XML directly and extract the media URL ourselves.
MP3 (Audio) – one single link
For the audio version there is exactly one MP3 link in the feed.
Command Line Sensor (MP3)
command_line:
  - sensor:
      name: "Tagesschau 100s MP3"
      command: >
        curl -fsSL
        "https://www.tagesschau.de/multimedia/sendung/tagesschau_in_100_sekunden/podcast-ts100-audio-100~podcast.xml"
      value_template: >
        {% set m = value | regex_findall('https?://[^"\\s]+\\.mp3') %}
        {{ m[0] if m | length > 0 else '' }}
      scan_interval: 300
This sensor:
  • loads the podcast XML
  • extracts the current MP3 URL
  • updates automatically whenever the feed changes
Play MP3 (example: Sonos)
service: media_player.play_media
  entity_id: media_player.living_room
  media_content_id: "{{ states('sensor.tagesschau_100s_mp3') }}"
  media_content_type: music
MP4 (Video) – multiple qualities available
The video feed contains multiple MP4 streams for different resolutions.
You can choose which one you want.
In this example, the sensor extracts the 1920p (Full HD) stream.
Command Line Sensor (MP4 – 1920p)
command_line:
  - sensor:
      name: "Tagesschau 100s MP4 URL 1920p"
      unique_id: tagesschau_100s_mp4_url_1920p
      command: >-
        curl -fsSL -A "Mozilla/5.0" "https://www.tagesschau.de/tagesschau_in_100_sekunden/"
      value_template: >-
          'url":"(https://tagesschau-progressive\\.ard-mcdn\\.de/video/[^&"\\s]+\\.webxxl\\.h264\\.mp4)'
        {{ m[0] if (m | length) > 0 else '' }}
      scan_interval: 300
      command_timeout: 30
You can adapt the regex if you prefer a different resolution.
Play MP4 (example: Tablet)
  entity_id: media_player.wall_tablet
  media_content_id: "{{ states('sensor.tagesschau_100s_mp4_1920p') }}"
  media_content_type: video
Why this approach works well
  • Uses official ARD podcast feeds
  • No HTML scraping
  • No downloads or local storage
  • Always plays the current episode
  • URLs are refreshed automatically
  • Works reliably with Sonos and tablets
Hi, is it possible to play the MP4 video on a dashboard as well (same machine not a third party media player)? I tried different picture cards and iframe but haven’t got it work out.
Thanks :slight_smile:
Hey. Did you make it? Warm regards
Hey no I couldn’t get it to work
I wish there would be an RSS scraper, that puts the whole XML / body of the RSS into a state, which i can then select.
I built a similar integration, but for HA to show nicely what the title of the media is playing, I would need another RSS scraper, to extract stuff like title and date of the most recent news.
Sorry for my late reply.
Yes it’s possible. Download the Ingress webpage card from HACS.
You can add a MP4 URL. It will then be displayed in the dashboard.
@Dananuel FYI
Thanks for your post. How must set the url in ingress webpage card?
type: custom:addon-iframe-card
url: >-
aspect_ratio: 50%
hide_background: true
it's doesnt work :frowning:
Only direct work
url: >-
  https://tagesschau-progressive.ard-mcdn.de/video/2026/0612/TV-20260612-1132-0900.webxxl.h264.mp4
aspect_ratio: 50%
The url ist stored in the state.
Nobody any idea to display the url from a state?
Can anyone help me, how can i do this with a state for the url or i need a another card?
That’s my solution:
type: markdown
content: |
  <center>
    <video id="Movie" src='{{ states('sensor.tagesschau_100s_mp4_url_1920p') }}' width='800' height='450' autobuffer autoplay controls><div>Sorry, not available!</div></video>
  </center>
grid_options:
  columns: full
  rows: auto
