I have just started using HA and so far most things have gone well. However I get the following warnings in the log:
2018-04-04 03:04:08 WARNING (SyncWorker_8) [homeassistant.components.tahoma] Unsupported type internal:TSKAlarmComponent for Tahoma device Alarm
2018-04-04 03:04:08 WARNING (SyncWorker_8) [homeassistant.components.tahoma] Unsupported type internal:PodV2Component for Tahoma device Active button
2018-04-04 03:04:08 WARNING (SyncWorker_8) [homeassistant.components.tahoma] Unsupported type io:SomfyContactIOSystemSensor for Tahoma device PatioDoor
2018-04-04 03:04:08 WARNING (SyncWorker_8) [homeassistant.components.tahoma] Unsupported type rtds:RTDSRemoteControllerComponent for Tahoma device Somfy Remote
2018-04-04 03:04:08 WARNING (SyncWorker_8) [homeassistant.components.tahoma] Unsupported type rts:VenetianBlindRTSComponent for Tahoma device Study
2018-04-04 03:04:08 WARNING (SyncWorker_8) [homeassistant.components.tahoma] Unsupported type rts:DualCurtainRTSComponent for Tahoma device Dining Room
Iâm not worried about the TSKAlamComponent, PodV2Component or the RTDSRemoteControllerCompoent but the VenetianBlindRTSComponent and the DualCurtainRTSComponent are my covers that I would like to control.
It would also be nice to have access to the SomfyContactIOSystemSensor.
Does anyone know what might be causing these warnings and how I can get my covers working?
My curtains and blinds now appear in the interface.
I played around with the tilt options on the Venetian blind but had no luck with making that work. I created a cover sub folder and copied the tahoma.py cover file to there. I then filled added the extra code for the tilt position and set the type of the blind to include the tilt buttons.With the help of some log messages I could see the code was being called but I couldnât work out what the Somfy commands are.
While I was there I made one of the tilt functions send âmyâ as the command and it did activate the My position on the blind. So what I could do with now is some clever person to tell me how I change the GUI to show a âMyâ button.
Maybe the cover implementation could be updated officially to support that as it is a standard feature of the Somfy covers.
All the covers I added work but the ârts:VenetianBlindRTSComponentâ only goes up/down. At the moment I have left one of the tilt functions sending âmyâ and programmed the âMyâ position on the blind to be all the way down with the slats horizontal. That allows me to select all the positions I need.
I thought the ContactIOSystemSensor was working as it appears i the GUI and i use it to open and close the curtains when the door opens / closes. However, I have just checked again and it just reports unknown all the time. Now I remember that I had already set it up to do that automation in the Tahoma box. I think I got side tracked by the Venetian tilt function and then forgot about the sensor.
I would VERY much appreciate support for the following 2 device types:
rts:BlindRTSComponent
rts:OnOffRTSComponent
The Blind supports in the TahomaLink application âUpâ, âDownâ and âMyâ.
The OnOff is just a switch with âOnâ and âOffâ.
I am able to connect to Tahoma and I received the following messages:
20188-04-18 17:46:57 WARNING (SyncWorker_7) [homeassistant.components.tahoma] Unsupported type internal:TSKAlarmComponent for Tahoma device Alarm
2018-04-18 17:46:57 WARNING (SyncWorker_7) [homeassistant.components.tahoma] Unsupported type internal:PodV2Component for Tahoma device Active button
2018-04-18 17:46:57 WARNING (SyncWorker_7) [homeassistant.components.tahoma] Unsupported type rts:BlindRTSComponent for Tahoma device Living 1
2018-04-18 17:46:57 WARNING (SyncWorker_7) [homeassistant.components.tahoma] Unsupported type rts:OnOffRTSComponent for Tahoma device Yard Lights
2018-04-18 17:46:57 WARNING (SyncWorker_7) [homeassistant.components.tahoma] Unsupported type rts:BlindRTSComponent for Tahoma device Living 2
2018-04-18 17:46:57 WARNING (SyncWorker_7) [homeassistant.components.tahoma] Unsupported type rts:BlindRTSComponent for Tahoma device Living 3
2018-04-18 17:46:57 WARNING (SyncWorker_7) [homeassistant.components.tahoma] Unsupported type rts:BlindRTSComponent for Tahoma device Living 4
2018-04-18 17:46:57 WARNING (SyncWorker_7) [homeassistant.components.tahoma] Unsupported type rts:BlindRTSComponent for Tahoma device Study
2018-04-18 17:46:57 WARNING (SyncWorker_7) [homeassistant.components.tahoma] Unsupported type rts:BlindRTSComponent for Tahoma device Kitchen
(I only care about the rts:BlindRTSComponent and rts:OnOffRTSComponent)
(currently going HA --> IFTTT --> Tahoma --> RTS Motor and would love to cut out IFTTT)
to the "def stop_cover(self, **kwargs): " function in covers\tahoma.py and I now have control of my blinds back where the GUI stop button sends the âmyâ command.
So if you would be so kind as to add those in officially I would be very grateful.
Hi
Today i also add tahoma to my Home Assistant and also have problem with devices on tahoma⌠Not show in Home Assistant⌠show warning in logâŚ
Unsupported type rtsExteriorVenetianBlindRTSComponent for Tahoma device Kuchnia
0816 componentstahoma.py (WARNING)
Unsupported type rtsExteriorVenetianBlindRTSComponent for Tahoma device Wykusz
Unsupported type rtsExteriorVenetianBlindRTSComponent for Tahoma device Balkon sypialnia
Unsupported type rtsExteriorVenetianBlindRTSComponent for Tahoma device Gabinet
Unsupported type rtsExteriorVenetianBlindRTSComponent for Tahoma device Swietlik sypialnia
Unsupported type rtsExteriorVenetianBlindRTSComponent for Tahoma device Wykusz boki
Unsupported type internalTSKAlarmComponent for Tahoma device Alarm
Unsupported type rtsExteriorVenetianBlindRTSComponent for Tahoma device Balkon MichaĹ
Unsupported type rtsExteriorVenetianBlindRTSComponent for Tahoma device Balkon Kinga
Unsupported type internalPodV2Component for Tahoma device Przycisk sensorowy
How i can add this devices and also add to mater component in developerâŚ
Where is located file tahoma.py ?
I have installed Home Assistant on my RPI3(no Hass.io)
