I have a 433Mhz device that i cannot get to identify in home assistant. and therefore i only have data from the homeassistant.log to show when it have been triggered.
The log when activated is:
2020-03-11 20:02:07 DEBUG (Thread-2) [homeassistant.components.rfxtrx] Receive RFXCOM event from (Device_id: 7635c7 Class: LightingDevice Sub: 0, Pkt_id: 0913007e7635c7021060)
2020-03-11 20:02:07 DEBUG (Thread-2) [homeassistant.components.rfxtrx.binary_sensor] Binary sensor update (Device ID: 7635c7 Class: LightingDevice Sub: 0)
2020-03-11 20:02:07 DEBUG (Thread-2) [homeassistant.components.rfxtrx] Device_id: 7635c7 device_update. Command: Unknown command (0x7635c7)
Im using the tail node on the homeassistant.log-file and can successfully use a string-node to search for “1111” (1111 used as an example. Actual command is in the logfile “0x7635c7”) and then send that to do something.
Now my question.
I have 5 devices that each sends a different command (1111, 2222, 3333 and so on) and i would like to combine a tail-node with string node and then a switch node to identify which device were triggered.
I.e. i would like to stream-line the flow as much as possible.
Any ideas?
