Tailscale add-on - exit node & subnet access
I’ve successfully installed and set up the Tailscale addon on my Pi3 HA. However I don’t need nor want Exit node nor subnet access. It appears set by default within the addon and on my web UI I can only see “viewing” mode; no picture icon to login and change settings. How do I turn it off on the HA machine. I realise it also has to be enabled within the Tailscale portal to work but I have no reason to enable it at all. On other Linux machines these settings are off by default and a cli command through a terminal session to enable them.
Same issue here. Is is reasonable to just ignore these warnings? If I don’t authorize in the Tailscale Admin UI, then the default node-to-node communication will function just fine?
I found the configuration options. They’re not within the web UI, they’re at the bottom of the addon page when using the app, at the top of the page when using a PC browser and hidden at the bottom of a tablet browser and pop up having scrolled to the bottom.
Select configuration and scroll to the bottom. Select “show unused optional configuration options”, select every option and then save. This populates the config file with everything ‘true’, then turn off or set false those that are not required. To disable subnet route access add a network, say 192.168.0.0/24, save, then edit the yaml and replace the network with “” (opposing square brackets).
Can you please add a scrreshot of your actual yaml, please?
I feel stupid but I can’t find the way to let him accept the opposing square brackets…
:frowning:
Thank you
Found my answer.
There must be a blank between the opposing square brackets
My config:
accept_routes: false
advertise_exit_node: false
advertise_routes: [ ]
Thanks, this was exactly what I was looking for.f
cant find where the yaml file is… hint please…
See the screenshot below
Once I have the YAML file, after activating all the “Show unused optional configuration options” I do not know which of those I have to turn off that are not required for the add-on to work.
I also need some help to disable the subnet route access. What network should I add (“say 192.168.0.0/24”?)?.
The bottom line is that I would like to use Tailscale connection to access HA when outside the local network without using a subnet and the exit node options or by activating the https domain in Tailscale. Thanks for helping.
These are the default settings but seems to not be enabled when the add on is installed?
advertise_routes:
I hit save and restarted without changing anything and the warnings went away
Thanks! The solution worked perfectly.
However, this behavior is a bit weird and counter-intuitive. When installing the add-on, the Exit Node and Connector options appear disabled in the configuration tab, but they’re actually enabled/advertised in the Tailscale admin console.
Maybe this is intentional behavior? Just thought it’s worth pointing out and maybe looking into.
Ok, now I see it’s a known topic, seems to be a problem with HA UI.
