I just installed the Tailscale Addon for HA… Everything is running fine. I enable SUBNET ROUTES on the server so i have remote access to devices to my local network including Home Assistant server.
I Also have a Freepbx server running on the same local network for my home voip phone… everything on my PBX system is working fine aslong that its on local… the problem is when i try to make a call using a softphone app “linphone” outside my network, my local voip phone rings and can answer the call and also hear the caller from the softphone… but when i speak thru the voip phone the other end cannot hear me…
Troubleshooting i tried to connect my softphone to local wifi… then make a call… only then audio works 2 way without issue… i dont know where could the problem be… i dont know if its on tailscale side or maybe the freepbx side… i posted here first before asking on tailscale and freepbx community, maybe someone here have been to the same issue.
