I am a bit at a loss here.
Having several HA’s running with nabu casa or duckdns and working fine.
I wanted to try Tailscale as it looked fast to setup on HA and on the other devices.
Installing went fine and also the Tailscale authentication is ok.
I have HA, an android device and a windows laptop in the network and pinging each of them works in the app.
But now the problem; I am unable to access the HA login. I get ERR_CONNECTION_TIMED_OUT
When i look in the logs of tailscale i see the following, when trying to connect via a smartphone or laptop:
2024/12/22 19:59:15 [RATELIMIT] format(“%s: %s %d %s\n%s”) (6 dropped)
2024/12/22 19:59:15 Drop: TCP{100.85.132.67:57219 > 100.101.122.28:8123} 52 no rules matched
2024/12/22 19:59:15 Drop: TCP{100.85.132.67:57222 > 100.101.122.28:8123} 52 no rules matched
I already tried tailscale on a RPI4 and odroid with the same problem, i even put the odroid on a different network at the neighbors but still no effect.
I seem to be missing something.
