I installed and started Tailscale but when I click on “open web-ui” I got the message as you can in the attachement and when I click on the button “reauthenticate” nothing happen. See attachement. I have an account with Tailscale. How can I solve this problem ?
Have you tried restarting the addon?
Yes I did. I also tried delete thé addon eb reinstall it.
Key’s for devices in Tailscale default to expiring in 90days.
You need to log onto your Tailscale account (login.tailscale.com), navigate to the “Machines” tab and you likely will see one or more machines that have expired. You can click on the three dots to the right of the machine to get a popup menu to perform actions. You will need to use the UI to create/replace a new key for the device. You can also choose to “Disable key expiry” in the same menu so this won’t happen again in 90 days.
Hope that helps.
Thx but it did not help
same here for me, did you find out how to solve?
Just ran into This problem. Solved it with the following steps on my phone!
- Open Settings
- Click add-ons
- Select Tailscale addon
- Select logs in the bottom right corner
- In your logs, you’re gonna look for a section that says, “ To authenticate visit…”
- Go to the URL and follow the steps. It was quite simple. Just had to login for me and since I already had an account and it already connected my iPhone it just worked.
here it is in Txt
2024/02/25 21:08:06 stopEngineAndWait...
To authenticate, visit:
https://login.tailscale.com/a/REDACTED
2024/02/25 21:08:06 requestEngineStatusAndWait
2024/02/25 21:08:06 tailscaleUp
I had this same problem. Turns out I had an Adguard filter preventing the login page from loading. Added a custom rule to allow the tail scale login page to load. Don’t ask me how many days it took me before I finally thought to check that.
Been there, done that. I’ve wasted countless hours troubleshooting stuff not working due to me having locked things down and forgetting later.
Thank you. This worked
The solution does not work for me. The log just says “No errors have been reported”.
Some notes:
- When the expiration occurred, I only noticed it from a sensor. I did not try to restart
my HA add-on. - Since the HA is remote, I could not reach it so I had to do a temporary expiry extension via tailscale admin console. It gave me the access but I dont see how to proceed.
I guess I have to wait for the temporary expiry to occur and then somehow force a restart of the HA add-on to make it write the link in the log file… How did you do?
Oh wow, I just added tailscale to the allowed domains on my pihole, hope this helps. Thank you!
