rraboy
(Randall)
May 20, 2024, 2:40pm
1
After upgrading tailscale to the 0.19.0, it stopped working completely.
Here are the relevant logs
Add-on: Tailscale
Zero config VPN for building secure networks
Add-on version: 0.19.0
You are running the latest version of this add-on.
System: Debian GNU/Linux 11 (bullseye) (amd64 / qemux86-64)
Home Assistant Core: 2024.5.4
Home Assistant Supervisor: 2024.05.1
Log level is set to TRACE
[10:32:18] INFO: Starting Tailscale web...
[10:32:18] INFO: Starting Tailscale...
[10:32:18] TRACE: bashio::addon.ip_address
[10:32:18] TRACE: bashio::config.has_value: userspace_networking
[10:32:18] TRACE: bashio::addons self addons.self.ip_address .ip_address // empty
[10:32:18] TRACE: bashio::cache.exists: addons.self.ip_address
[10:32:18] TRACE: bashio::config: userspace_networking
[10:32:18] TRACE: bashio::fs.file_exists: /tmp/.bashio/addons.self.ip_address.cache
[10:32:18] TRACE: bashio::addon.config
[10:32:18] INFO: Allow UDP GRO for forwarding on enp1s0
[10:32:18] TRACE: bashio::var.false: self
netlink error: bit name not found (offset 56)
netlink error: Not supported
[10:32:18] TRACE: bashio::cache.exists: addons.self.options.config
s6-rc: warning: unable to start service post-tailscaled: command exited 92
[10:32:18] TRACE: bashio::cache.exists: addons.self.info
My system:
root@ha:~# cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
NAME="Debian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
root@ha:~# dpkg-query --list | grep homeassi
ii homeassistant-supervised 1.4.1 all Home Assistant Supervised
root@ha:~# ha info
arch: amd64
channel: stable
docker: 26.1.3
features:
- reboot
- shutdown
- services
- network
- hostname
- timedate
- os_agent
- resolved
- disk
hassos: null
homeassistant: 2024.5.4
hostname: ha
logging: info
machine: qemux86-64
operating_system: Debian GNU/Linux 11 (bullseye)
state: running
supervisor: 2024.05.1
supported: false
supported_arch:
- amd64
- i386
rraboy
(Randall)
May 20, 2024, 6:34pm
2
It turns out the 0.19.0
is somewhat broken with my setup.
I found a way to revert this temporarily by renaming its docker image 0.19 to 0.18
Make sure the tailscale add-on is stopped. Then, do
docker pull ghcr.io/hassio-addons/tailscale/amd64:0.18.0
docker tag ghcr.io/hassio-addons/tailscale/amd64:0.18.0 ghcr.io/hassio-addons/tailscale/amd64:0.19.0
Then restart the add-on.
dj-eon
(Ian T.)
May 21, 2024, 5:03pm
3
Yes, I’ve seen this problem today. Luckily I’d checked “Create backup before update” enabled, so just restored that.
Same, restoring from a backup made the trick. DAMN TAILSCALE!!
tvds
(Tim)
May 23, 2024, 5:58pm
5
I have the same problem. I’ve also made a backup. Can you just restore the tailscale addon? Or do you need to run the whole HA restore?
Edit: you can just partially restore. Fixed now
dj-eon
(Ian T.)
May 23, 2024, 8:03pm
6
I also noticed today that the (I think it was) 0.19.0 pending update has now disappeared, so the dev guy(s) are well aware of the issue.
I’m a bit of a novice with Linux in general, so I regularly backup the whole drive as well as using the backup in home assistant before I make any changes.
rraboy
(Randall)
May 25, 2024, 1:08am
7
I didn’t realize about the backup. It is too late for me to use the backup now.
rraboy
(Randall)
May 25, 2024, 4:17pm
8
I just noticed that 0.19.1 was released. Given I was using a workaround using docker tagging, it overwritten it and still doesn’t work.
chrizzzp
(chrizzz)
May 26, 2024, 11:00am
9
Same problem here. I also reverted back to the addon version 0.18, which still works (although in the tailscale web UI machine overview there is a warning that the used tailscale version 1.64.0 has security vulnerabilities).
Addon versions 0.19 and 0.19.1 both didn’t work.
I guess we should open an issue here .
chrizzzp
(chrizzz)
June 10, 2024, 6:26am
10
Addon version 0.20 is out. Did anyone try if the problem is fixed?
dj-eon
(Ian T.)
June 10, 2024, 6:09pm
11
I’ve updated to 0.20 and its stopped working again.
chrizzzp
(chrizzz)
June 14, 2024, 4:49am
12
OK, I’m still at 0.18. So maybe someone with 0.20 should report the problem with logs here . As the add-on is actively developed I think there is a good chance it will be fixed.
chrizzzp
(chrizzz)
July 21, 2024, 4:39pm
13
Now, tailscale addon version 0.21.0 is out. Is the problem fixed?
Edit: 0.21.0 seems to work again! Upgraded from 0.18 without problems.
