Is that any easy nice way in Node-Red to take a snapshot from my ffmpeg camera?
I have add so the camera show in Home Assistant (I can see it from lovelace) but after that I’m not sure.
There is a service called camera.snapshot, have you looked at it?
Thanks for the replay
Yes I have, but have no idea how to connect that to Node-RED.
Change the entity to your camera notify your phone. Also change the camera in the data portion.
[{"id":"369b3bc42a7cfbd4","type":"debug","z":"f80b6c338afd5483","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":2030,"y":320,"wires":[]},{"id":"e3774f41205b8832","type":"api-call-service","z":"f80b6c338afd5483","name":"Notify Phone","server":"6b1110b5.183a4","version":5,"debugenabled":false,"domain":"notify","service":"mobile_app_pixel_3","areaId":[],"deviceId":[],"entityId":[],"data":"{\t \"title\":\"Title\",\t \"message\":\"message body\",\t \"data\":{\t \"image\": $entities('camera.g3_instant_high').attributes.entity_picture\t }\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1770,"y":360,"wires":[["369b3bc42a7cfbd4"]]},{"id":"eee87d98697d1aa3","type":"inject","z":"f80b6c338afd5483","name":"","props":[{"p":"payload"},{"p":"entity_id","v":"light1","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"on","payloadType":"str","x":1570,"y":480,"wires":[["e3774f41205b8832"]]},{"id":"6b1110b5.183a4","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"30"}]
I use Pushbullet and when I edit your data code so it fit Pushbullet nothing happend.
“title”:“Testing”,
“message”:“Send a Pic”,
“data”:{
“file”: $entities(‘camera.kameraframsidan’).attributes.entity_picture
I think it have to take a snapshot from ffmpeg stream, save it local on the server and then send that picture with pushbullet.
I have this one:
"id": "f064b1c8.79676",
"type": "api-call-service",
"z": "d4d658ef.680968",
"name": "Record 15s",
"server": "5eeca57f.edcfdc",
"version": 5,
"debugenabled": false,
"domain": "camera",
"service": "record",
"areaId": [],
"deviceId": [],
"entityId": [
"camera.{{payload}}"
"data": "{\"duration\": \"15\", \"entity_id\":\"camera.{{payload}}\",\"filename\":\"/config/www/images/camera/{{payload}}.mp4\"}",
"dataType": "json",
"mergeContext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "none",
"x": 650,
"y": 80,
"wires": [
"cc1ccf0a.c0f16"
"id": "e17e11ae.d7f7a",
"type": "inject",
"name": "",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 160,
"y": 120,
"wires": [
"e2677d76.e4bf"
"id": "51e2d6d4.7f3d88",
"type": "function",
"name": "",
"func": "msg.payload = \"voordeur_hd zijgevel_hd voortuin_hd\";\n\nvar outputMsgs = [];\nvar words = msg.payload.split(\" \");\nfor (var w in words) {\n outputMsgs.push({payload:words[w],camera:words[w]});\n}\nreturn [ outputMsgs ];",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"x": 460,
"y": 80,
"wires": [
"f064b1c8.79676",
"d825a97.cd41958"
"id": "cc1ccf0a.c0f16",
"type": "delay",
"name": "",
"pauseType": "delay",
"timeout": "40",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"outputs": 1,
"x": 800,
"y": 80,
"wires": [
"76c6c166.f5ddb"
"id": "76c6c166.f5ddb",
"name": "Send to telegram",
"version": 5,
"domain": "notify",
"service": "telegram_voordeur",
"areaId": [],
"deviceId": [],
"entityId": [],
"data": "{\"message\":\"Dummy\",\"data\":{\"video\":{\"file\":\"/config/www/images/camera/{{camera}}.mp4\",\"caption\":\"Opname van {{camera}}\",\"timeout\":180}}}",
"dataType": "json",
"mergeContext": "",
"queue": "none",
"x": 970,
"y": 80,
"wires": [
"id": "940e4107.350de",
"type": "link in",
"name": "Snapshot camera's => Telegram",
"links": [
"94082261.9f664"
"x": 195,
"y": 60,
"wires": [
"e2677d76.e4bf"
"id": "d825a97.cd41958",
"name": "Snapshot",
"version": 5,
"domain": "camera",
"service": "snapshot",
"areaId": [],
"deviceId": [],
"entityId": [
"data": "{\"filename\":\"/config/www/images/camera/{{payload}}.jpg\"}",
"dataType": "json",
"mergeContext": "",
"queue": "none",
"x": 640,
"y": 140,
"wires": [
"d78e8772.226728"
"id": "d78e8772.226728",
"type": "delay",
"name": "",
"timeout": "5",
"rate": "1",
"nbRateUnits": "1",
"randomFirst": "1",
"randomLast": "5",
"drop": false,
"outputs": 1,
"x": 800,
"y": 140,
"wires": [
"2ea83f6d.9dbde"
"id": "2ea83f6d.9dbde",
"version": 5,
"domain": "notify",
"areaId": [],
"deviceId": [],
"entityId": [],
"data": "{\"message\":\"Dummy\",\"data\":{\"photo\":{\"file\":\"/config/www/images/camera/{{camera}}.jpg\",\"caption\":\"Snapshot van {{camera}}\"}}}",
"dataType": "json",
"mergeContext": "",
"queue": "none",
"x": 970,
"y": 140,
"wires": [
"id": "e2677d76.e4bf",
"type": "api-current-state",
"name": "Thuis?",
"version": 3,
"outputs": 2,
"halt_if": "on",
"halt_if_type": "str",
"halt_if_compare": "is",
"entity_id": "input_boolean.thuisaanwezig",
"state_type": "str",
"blockInputOverrides": false,
"for": 0,
"forType": "num",
"forUnits": "minutes",
"x": 310,
"y": 100,
"wires": [
"51e2d6d4.7f3d88"
"b3510ef9.fea81"
"inputLabels": [
"Afwezig triggered"
"id": "b3510ef9.fea81",
"type": "function",
"name": "",
"func": "msg.payload = \"voordeur_hd zijgevel_hd voortuin_hd achtergevel_hd\";\n\nvar outputMsgs = [];\nvar words = msg.payload.split(\" \");\nfor (var w in words) {\n outputMsgs.push({payload:words[w],camera:words[w]});\n}\nreturn [ outputMsgs ];",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"x": 460,
"y": 140,
"wires": [
"f064b1c8.79676",
"d825a97.cd41958"
"id": "5eeca57f.edcfdc",
"type": "server",
"name": "Home Assistant",
"version": 2,
"addon": false,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": 30
You probably can find some inspiration in it, if questions, don’t hesitate
Hi and thanks for the code
Not sure why because you code does look like my but yours is working
So now I have got it to work so thanks alot for all the help guys.
Is this a cut and paste from the node? The formatting is wrong so it definitely won’t work the way it is. If there is a red line around any box there is an error there.
"title":"Title",
"message":"message body",
"data":{
"file": $entities('camera.kameraframsidan').attributes.entity_picture
I do not remember any red line, I have try alot of code over one day that I don’t remember
But now it works and I’m very happy with that.
