Take action when home becomes empty, occupied
Hello :wave:t2:
Sharing two very simple blueprints that I think could be useful for beginners
Take actions when the home becomes empty (When the last person leaves home):
The blueprint asks you to select the zone that corresponds to your home.
You can pick the action you want to perform once the home becomes empty.
By default, an action is present and turns off all lights in the home, you are free to use it or remove it.
Take actions when the home becomes occupied (When the first person arrives home):
You can pick the action you want to perform once the home becomes occupied.
There is no default action in this case.
I hope it will help beginners :wink:
Source code
JLo
I’m looking for almost exactly that, would you know how to enhance this blueprint with a duration?
I have already built myself a similar automation manually but my issue is that my position keeps jumping out of home and back in a few minutes later because of some unknown reason… Same happens on the phone of my wife. When we’re both home it never happens at the same time so no issue but when only one is home such an automation sucks because it’s triggered immediately when our position is buggy…
If I could ensure the home is empty “for at least 10-15 minutes” it would be helpful in avoiding such false triggers.
In parallel I’m looking for other means to avoid the false triggers, my WiFi access point having an integration I could probably have it check that out phones are not connected to the home wifi before acting on “the home becoming empty”
Thanks in advance for any help
***** SOLVED *****
Hi jenova70, I have been using these 2 scripts to Arm and Disarm my Ring alarm but for the last few days it seems to have developed an issue.
when we are both away the alarm arms as expected then disarms then repeats every few minutes until I disable the automations, this happens all the time even though on the companion app > maps it shows us both away.
it is like the phone is dipping in and out of the home zone.
Any advice?
Thanks, Terry
Are there any other device trackers associated with your persons that remain at home?
I would set up a history window with the person and device tracker entities and watch or review them after you experience this.
Yep, what @Cake1468 said. Check the history of all your device trackers, especially if you have a device you usually leave at home (like a tablet)
O dear, Im a dummie… it seems that after an APP update it changed my mobile phone name in Persons so was seeing me as away all the time…
I do feel Stupid :confused:
Terry
Thanks for reply, I replied to Cake above but as expected, it was MY fault :smiley: Terry
It’s all good. I’ve fought lots of weird little things like that.
