Take out a part of a string , and do an action
hi, i have a sensror, thats reading a hex string
for example
01000100…
every light in my house is 2 bits long, so this means (in example above)
light 1 : 01 (on)
ligth 2 : 00 (off
ligth 3 : 01 (on)
light 4 : 00 (off)
so i have an 4 automation configured:
automation 1
      - condition: template
value_template: "{{ is_state('sensor.hex', '01000000') }}"
but this is not working ffcourse , because i read the whole line
how can i only read the first 2 values, and ignore the rest
for automation 2 , i only need to read 3 th and 4th character and igore the rest
how can i read that ?
sensor.hex AND FF000000 for light 1, sensor.hex AND 00FF0000 for light 2 etc.
I don’t think you can use is_state, which is too bad, but this should work:
First automation:
value_template: "{{ states.sensor.hex.state[0:2] == '01') }}"
Second automation:
value_template: "{{ states.sensor.hex.state[2:4] == '01') }}"
and so on.
If you use the state of the lights in several places, perhaps make template sensors for each light and use them in the automations.
cool, i can use that :slight_smile: , thnx for fast answers
indeed, i can make multiple sensors, but in programming time it takes the same amount of time
i have a domotica system, with no integrations or bindings whats so ever , but i cand send and read out TCP commands, in hex format, based on a 48 bit long string i know the output of my lights, etc …
so i have one sensor to read out my whole home, then based on automation, i am going to change the state of a switch
because it can happen offcourse, it we put the light on on a classic switch outside of HA, then offcourse HA needs to change the state also, but without actually turning it off/on
thnx!!
btw, isnt that wrong? shouldt it be : state[0:1] , so only first 2 digits
You are new to ha by the sound of it. In ha this is a ‘light’ not a ‘sensor’. And each light is a single entity, although you can group a number of lights if you want to have them all act together.
ok, thnx, well i just test t :slight_smile:
The slice notation is the same as pythons (I think), so [0:2] returns indexes 0 to 1, and [2:4] returns indexes 2 to 3.
Try it in the Templates editor: {{ '0123456'[0:2] }} returns 01
The first digit is the first index to include and the second is the first index to NOT include. Sounds strange, but works well.
Ok, thnx for the explanation
hmm, i tried your line in my automation
    value_template: "{{ states.sensor.Prog.state[0:2] == '01') }}"
gives an error :
nvalid config for [automation]: invalid template (TemplateSyntaxError: unexpected ‘)’) for dictionary value @ data[‘condition’][0][‘value_template’]. Got None
not a valid value for dictionary value @ data[‘condition’][0][‘condition’]. Got None
required key not provided @ data[‘condition’][0][‘entity_id’]. Got None.
if i change it , how i did it before, on my old config, just reading sensor by sensort
then i dont have an program script error, but it doesnt work either, doesnt start the automation
value_template: "{{ is_state('sensor.Prog[0:2]', '01') }}"
Remove the ) after ‘01’
"{{ states.sensor.Prog.state[0:2] == '01' }}"
omg, didnt notice !! just copy pasted it from above
thnx!
