Taking a backup of ZHA using bellows on Home Assistant OS
I have a VM running Home Assistant OS, I’ve seen that you can run a bellows command to take a backup of the ZHA config?
How do I do this? I’ve SSHed into the box through the plug in and connected to the local console.
Neither of which seem to allow me to either run or install bellows.
If it works then the easiest would be to use the blueprint for zha-toolkit as then backups could be done online without stopping ZHA
https://github.com/mdeweerd/zha-toolkit
https://community.home-assistant.io/t/daily-zigbee-coordinator-backup-blueprint-znp-ezsp-bellows/377149
https://community.home-assistant.io/t/zha-toolkit-toolkit-providing-low-and-high-level-zigbee-commands-through-zha-zigpy/373346
Otherwise you for now would need to stop/disable ZHA to perform offline backup via bellows directly:
https://github.com/zigpy/zigpy/wiki/Coordinator-Backup-and-Migration
https://github.com/zigpy/bellows/blob/dev/README.md#nvram-backup-and-restore
PS: Regardless consider vote to show interest → ZHA integration to do nightly backup of both Zigbee Coordinator adapter/dongle/stick and Zigbee database?
