Taking Control & Variables
Hi Team,
Playing around with Blueprints (others that is).
I was wondering if I “take control” should the Variables stored in automation still work?
Thanks advance.
Stephan
They will. The blueprints will retain your settings but be converted to static automations in which your variables become hard-coded.
I believe you can preview your new automation before committing to migrate.
If you want to alleviate your concerns you could always do a test run with an automation freshly created from a blueprint and take control of that to better understand the process.
