Tap_action and Hold_action with two different entities possible in one button card?
Is it possible to use a button card or a custom: button card and use two entities for it ?
I have an shelly switch to turn on a smart light and when the light is on I like to change for example the color temperature.
With one button card I want to us the tap_action for toggle the switch entity and with the hold_action I want to fire the service: more-info for the light entity.
Is this possible ?
Yes, this is possible with custom:button-card :
hold_action:
  action: more-info
  entity: light.xy
Thanks for you reply but I can get it to work. I use the code below.
But with the hold-action I get the more-info on the switch entity and I want the
more-info on the light entity.
If you have more tips, it’s most appreciated.
type: button
entity: switch.xy
tap_action:
  action: toggle
hold_action:
  action: more-info
  entity: light.xy
My example is part of custom:button-card. I’ve corrected it in my previous post.
Ah, thanks. With the custom: button-card it’s working nicely.
