Tap_action more-info in decluttering_templates not working
Using this template
decluttering_templates:
  device:
    card:
      type: custom:mushroom-template-card
      primary: "[[name]]"
      secondary: "{{ states('[[entity]]') | int}}"
      icon: "[[icon]]"
      icon_color: >
        {% set p = states('[[entity]]') | int%}
        {% if p > 1000 %}
          red
        {% elif p > 100 %}
          orange
        {% elif p > 0 %}
          green
        {% endif%}
      entity: [[entity]]
      tap_action:
        action: more-info
      layout: vertical
      multiline_secondary: false
      - type: horizontal-stack
        cards:
          - type: custom:decluttering-card
            template: device
            variables:
              - name: UPS Tot
              - entity: sensor.shellypro4pm_c8f09e8877e0_switch_0_power
              - icon: mdi:power-plug
the tap_action does not work.
While if I do not use the template and I use this code:
        cards:
            primary: UPS Tot
            secondary: "{{ states(entity) | int}}"
            icon_color: >
              {% set p = states(entity) | int%}
              {% if p > 1000 %}
                red
              {% elif p > 100 %}
                orange
              {% elif p > 0 %}
                green
              {% endif%}
            tap_action:
              action: more-info
            layout: vertical
tap_action more-info works fine.
I use the template “device” in many places of my dashboard and it would be great to make the tap_action more-info work from there. I tried navigate instead of more-info in the template and it works.
Many thanks
Try with
entity: ‘[[entity]]’
(Posting from iOS, it uses wrong quotes - so replace them by a proper quotes)
And suggest to post in a dedicated decluttering-card thread instead of cluttering the forum by new threads.
