Tapo c200 setup in Fregate with audio & PTZ
Pls help with the right code to see my cam in frigate
Hi Witzker,
First step is to read this.
It will help you form a question that others have the ability to answer.
“There is indeed a formulated question - Sir_Goodenough!”
If you’d like, I can help rephrase or expand on it further If you have problems to get it!!
Let me know!
BUT a possible answer would have been this:
mqtt:
  host: 192.168.178.109
  port: 1883
  topic_prefix: frigate
  client_id: frigate
  user: #{mqtt user}
  password: #{mqtt password}
  stats_interval: 300
go2rtc:
    EundE_EINGANG-Innen:
      - rtsp://USER:[email protected]:554/stream1
    Eunde-EINGANG-Innen_sub:
      - rtsp://USER:[email protected]:554/stream2
birdseye:
  enabled: true
  mode: continuous
  layout:
    scaling_factor: 3.0
cameras:
    Eunde-EINGANG-Innen:
    birdseye:
      order: 1
    onvif:
      host: 192.168.178.51
      port: 2020
      user: USER
      password: PW
    ffmpeg:
      inputs:
        - path: rtsp://USER:[email protected]:554/stream2
          input_args: preset-rtsp-restream
          roles:
            - detect
        - path: rtsp://USER:[email protected]:554/stream1
          roles:
            - record
    detect:
      enabled: true
      width: 640
      height: 480
      fps: 10
    objects:
      track:
        - person
      filters:
        person:
          min_score: 0.4
          threshold: 0.5
          min_area: 700
version: 0.14
camera_groups:
  Birdseye:
    order: 1
    icon: LuActivity
    cameras:
      - birdseye
      - EundE_EINGANG
So, this is a starting point. How could the code be further improved?
Let me know if you’d like any adjustments!
Maybe recording to Synology.
Two Way audio - BUT WITHOUT - Cloud PW!
else…?
@Sir_Goodenough
And please - Don’t explain what you didn’t understand, but stay on topic if you can contribute something to the code!
