Hello.
Can someone help me how to get binary sensor person detection in Tapo c310 integration.
The motion sensor works great but detects everything. Thank you
This request is also outstanding in the HACS-based Tapo integrationâŠawaiting for someone to spend time on it.
hey guys, I recently started using Home assistant and connected my C310 ending at the point you guys at.
But Iâm slightly confused as they already implemented the âPerson Detectionâ mode but there is no sensors for this to also push a notifcation to the Logbook
Am I missing something to add the sensor? Been trying to manipulate the Motion Entity ID to Person detection but it seems to have no affect.
Hope anyone found a work around.
Regards
This is motion detectionâŠthere is an added feature of âpersonâ detection
There is a settings option for âmotionâ and âpersonâ detection. But sadly on the settings option you can receive on your phone Tapo app then.
Anyways, has anyone of you a work around to save the record on your Server once the motion sensor was triggered? Since the person detection isnât available as alert yet I assume its only doable for motion.
Would highly appreciate.
Using Home assistant on Proxmox
Same here with C320WS and C110 cams: person detection works like a charm in Tapo app, but I have a LOT of false alarms in HASS - based on the standard motion detection onvif event.
Shadows in the daytime, tiny bugs at night⊠completely unuseable for automation.
I also started the trial period of Tap Care service to check if they have any kind of notification (e-mail or something), but I canât see any.
I tried to use my Synology NVRâs person detection feature, but it needs at least a 25fps stream to work - what a shame that tapo cameras are maximized in 15âŠ
So it doesnât work either ![]()
Iâm not in app development and packet capturing techniques, but what if one just installs Tapo app in an android emulator and monitors the communication between Tapo app and the cameras/servers?
Anyone tried this?
Or is this kind of reverse engineering a completely bad direction?
Any help appreciated!
Hi all. For what itâs worth, hereâs my apporach to getting HA alerts when a person is detected (I have a TP-Link Tapo C320W camerag). My camera only tells me about motion detections, not any other detections. This approach is a bit bare, but it works:
High level overview:
I use a python script to poll my camera for all events that occured, filter for the âperson detectedâ event and send a message to HA using MQTT.
The approach:
- Make sure you have a MQTT broker running
- Hereâs a nifty method (from the pytapo library, bless their souls) that allows you to read all events from your Tapo Camera that occured between two timeframes.
- Use a python script to poll the camera events and match on the âperson detectionâ alarm type
- Use
AppDaemonto run the python script (or another way if you have one, but just make sure that the script can access your network) - Send a MQTT message whenever the âperson detectedâ event happened.
The code
Be sure to to install the pytapo and paho-mqtt libraries.
hereâs the code:
import appdaemon.plugins.hass.hassapi as hass
from paho.mqtt import client as mqtt
from pytapo import Tapo
from datetime import datetime
import time
import json
TRANSPORT = "tcp"
BROKER_ADDRESS = "your-broker-ip"
BROKER_PORT = 1883
BROKER_USERNAME = "broker-username"
BROKER_PASSWORD = "broker-password"
PERSON_DETECTED_ALARM_TYPE = 6
# See https://github.com/JurajNyiri/pytapo/blob/2a28236dfd885947d93f6a98ac1b10cdb0b731d4/pytapo/__init__.py#L677
# To check that `6` is also your camera's `person detected` alarm type, open a python shell, run the code to
# instantiate a tapo client (see code below), let your camera detect a person, call the
# tapo_client.getEvents(startTime=now - 60*10) to see the events for the past 10 minutes and check the last
# event's alarm type ID
ENTITY_ID = "tap_camera" # Give your entity a name
TOPIC= "tapo/person_detected" # change this to your liking
DISCOVERY_TOPIC = f"homeassistant/binary_sensor/{ENTITY_ID}/config"
CAMERA_IP = "camera ip" # make sure this is static
CAMERA_USERNAME = "camera-username"
CAMERA_PASSWORD = "the-camera-password"
INTERVAL_SEC = 5
BIRTH_TOPIC = f"homeassistant/binary_sensor/{ENTITY_ID}/status"
BIRTH_PAYLOAD = "online"
WILL_TOPIC = f"homeassistant/binary_sensor/{ENTITY_ID}/status"
WILL_PAYLOAD = "offline"
UNIQUE_ID = "3e73ef97-470b-5555-6666-f0b59d0552ce" # You can use another unique id here as well, just make sure is
# doesn't change
class TapoEventListener(hass.Hass):
def initialize(self):
self.mqtt_client = None
self.tapo_client = None
self._setup_clients()
self._enter_loop()
def _send_message(self, client, message):
client.publish(TOPIC, message)
def _publish_discovery(self, client):
discovery_payload = {
"name": "Person Detected",
"state_topic": TOPIC,
"payload_on": "detected",
"payload_off": "clear",
"device_class": "motion",
"unique_id": UNIQUE_ID,
"object_id": UNIQUE_ID,
# Publish the discovery message to the discovery topic
client.publish(DISCOVERY_TOPIC, json.dumps(discovery_payload), retain=True)
def _setup_clients(self):
# MQTT
self.log("Creating MQTT client...")
self.mqtt_client = mqtt.Client()
self.mqtt_client.username_pw_set(BROKER_USERNAME, BROKER_PASSWORD)
self.log("Setting will message...")
self.mqtt_client.will_set(WILL_TOPIC, WILL_PAYLOAD, qos=1, retain=True)
self.log("Connecting...")
self.mqtt_client.connect(BROKER_ADDRESS, BROKER_PORT)
self.log("Publishing discovery payload...")
self._publish_discovery(self.mqtt_client)
self.log("Sending birth message...")
self.mqtt_client.publish(BIRTH_TOPIC, BIRTH_PAYLOAD, qos=1, retain=True)
# Camera
self.log("Creating Tapo Camera client...")
self.tapo_client = Tapo(CAMERA_IP, user=CAMERA_USERNAME, password=CAMERA_PASSWORD)
def _enter_loop(self):
self.log("Entering loop...")
now = int(datetime.timestamp(datetime.now()))
self.tapo_client.getEvents(startTime=now - INTERVAL_SEC)
try:
while True:
person_detected = False
events = self.tapo_client.getEvents(startTime=now - INTERVAL_SEC)
self.mqtt_client.reconnect()
for event in events:
alarm_type = event["alarm_type"]
if alarm_type == PERSON_DETECTED_ALARM_TYPE:
self.log(f"Person detected!")
person_detected = True
self._send_message(self.mqtt_client, message="detected")
break
if not person_detected:
self._send_message(self.mqtt_client, message="clear")
time.sleep(INTERVAL_SEC)
except Exception as e:
self.log(f"An error occured:\nError:{e}.\nExiting")
exit(1)
A few notes:
- I do not know if the Tapo Cameraâs API has a rate limit, but I guess there is one. Have no idea what it is, so be careful with the
INTERVAL_SECvariable. - This script was not tested rigorously. Any suggested improvements are super welcome.
- Notifications through HA is obviously not as snappy as those from the Tapo app, but thereâs max INTERVAL_SEC ± 1 sec delay from detection to notification.
P.S
If you want to make this robust against camera reboots, youâll have to update the loop by swapping the while and try-except blocks. Something like:
while True:
try:
self.log(f"Events: {events}")
break
self.log(f"An error occured:\nError:{e}")
Is there a solution for this?
Thank you Chris, youâre awesome!!!
Clearly, pytapo library is the solution.
Which worked for me:
When HA receives a motion detection event from the Tapo camera, I simply run this code from shell (get_detection_type.py):
INTERVAL_SEC = 60 # get the most recent alarm from the last 60 seconds
tapo = Tapo("camera ip","camera user","camera password")
tapo_info = tapo.getEvents(int(datetime.timestamp(datetime.now())) - INTERVAL_SEC)
if len(tapo_info)==0:
print("0")
else:
print(tapo_info[0].get("alarm_type"))
It returns a numeric value (detection type):
- 0: No Detection (in the time given interval)
- 2: Motion Detected
- 4: Line-Crossing Detected
- 5: Area Intrusion Detected
- 6: Person Detected
- 8: Vehicle Detected
I run my automated tasks according to the answer - simple and works like a charm!
Thanks again!!!
UPDATE:
I also created my own rest sensor (in configuration.yaml):
- platform: rest
resource: http://myserver/tapo/detection_type.php
unique_id: dtype
The simple http based endpoint (detection_type.php):
<?php
$command = "python3 get_detection_type.py 2>&1";
$out = shell_exec($command);
echo $out;
âŠand finally!
The working detection_type sensor of my Tapo camera:
The default scan_interval in RESTful API is 30s, so HA reads the rest sensor every 30 seconds - itâs obviously not necessary to refresh the sensor at all, it only changes when we get a motion event from the camera, so we can call it manually, but itâs good to know that it works without issues, seems the Tapo API doesnât have a strict(?) rate limit.
Hey., thanks for the update and does this work with both your camera types?
Just tested and yes, it also works!
FYI: if you keep getting âInvalid authentication dataâ messages from the c110, use this login method, it solved the problem for me:
use âadminâ username and your cloud password
Tried using your approach but Iâm getting the following exception:
Any ideas? tapo.getBasicInfo() for example works, Iâm using a Tapo C320WS
Traceback (most recent call last): File â/var/www/html/get_detection_type.pyâ, line 13, in tapo_info = tapo.getEvents(int(datetime.timestamp(datetime.now())) - INTERVAL_SEC) File â/usr/local/lib/python3.9/dist-packages/pytapo/init.pyâ, line 688, in getEvents responseData = self.executeFunction( File â/usr/local/lib/python3.9/dist-packages/pytapo/init.pyâ, line 510, in executeFunction raise Exception( Exception: Error: -71114, Response: {âmethodâ: âsearchDetectionListâ, âresultâ: {}, âerror_codeâ: -71114}
I was in the same situation as you and I was going crazy. The solution is to put an SD card in the camera!
Nice!
This works without internet connection in the camera?
Works person dtection only put sd?
