deano12
(Dean Smith)
October 7, 2024, 3:53pm
1
Hi there, looking to see if anyone has been able to link up their Tapo Video Doorbell to HA - It worked to begin with, then suddenly started to fail with an auth error message.
The product in question is: Tapo D210 | Tapo Video Doorbell Camera | Tapo
jchh
((not John))
October 7, 2024, 4:20pm
2
Works for me but avoiding any firmware update until the auth problem is addressed
opened 08:53PM - 13 Apr 24 UTC
Bug
Blocked
# Thread for invalid cloud password on firmware build 230921 and higher
**Not… ice: This issue has been locked for discussion, and will be used to post updates only.** [Discuss](https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/discussions/categories/discuss) or ask a [question](https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/discussions/categories/q-a).
There has been reports of users on firmwares 1.3.8, and newer, or on some cameras other firmwares with build 230921 and newer of integration stopping to work. This shows as cloud password not being accepted.
I have been in touch with tplink regarding a security vulnerability I reported in the past and this is most probably a fix for it.
This currently only affects some users, not all and most probably requires camera to be connected to the internet in order to receive the update for authorization, given that it affects older firmwares as well, or possibly an interaction with the official app.
I have a [solution](https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/551#issuecomment-2118381739) that was [rejected by TPLink to be released](https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/551#issuecomment-2363817573). However, they are working on adding a new feature to the app that would allow integration to connect to cameras. They expect this to be released by mid-november 2024.
Users reported this problem in numerous issues, this issue will serve for tracking the progress on the fix and group all the conversation under one issue.
## Workarounds
If you wish to use this integration, until this issue is resolved, you will need to either:
1. If your camera still works with integration: Block internet access of camera if you are using firmware build 230921 and higher
2. If your camera no longer works with integration: [Block internet access and factory reset camera](https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/blob/main/add_camera_with_new_firmware.md) or [Use older firmware](https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/discussions/625) than build 230921 and optionally factory reset camera
## This post will stay uptodate with the most recent updates below.
2024-04-11:
First report of the issue at https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/549
2024-04-12:
Second report of the issue at https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/550 along with more users confirming the issue.
2024-04-13:
This thread has been created.
From my side, I have unblocked one of my camera on the latest firmware to reach the internet, so that hopefully I can get this update soon and work on a fix. I hope TPLink will provide detailed instructions on what has been changed so that I can work on a fix.
2024-04-19:
Added instructions about build number as some cameras have different versioning of firmwares.
I reached out to TP-Link after 7 days for any updates.
2024-04-23:
@reypm found a solution how to workaround this issue without [downgrading](https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/551#issuecomment-2061039421) the firmware:
> 1. Factory reset the camera (it remains with 1.3.11 Build 231117 firmware since I could not find a way to downgrade the firmware)
> 2. Entirely block Internet access for the camera
> 3. Reinstalled the component (this component)
> 4. Re-added the camera (by reinstalling the component it removes the old config)
TPLink is working on providing me with the solution, got a reply today that I need to wait a bit more.
2024-05-08:
I have some very good news and a little bit of concerning news.
Good news:
1. Today I was finally affected with this on one of my cameras which allowed me to conduct research and I spent my whole day working on that.
2. I now know how to solve this, I just need to figure out some of the remaining details and implement the changes which should not take more than a few weekends of active work. There is a lot of work involved but it can be done and I now know roughly how.
Now the concerning news:
1. Integration will need to interact with tplink cloud to get the new password. This is possibly a one time job, but I do not know yet, it might expire and get a new password if it no longer works. I will need to find a way to detect this as well but thats just a little detail.
2. Due to integration's need to interact with TPLink cloud I have reached out to TPLink for their permission. If they refuse, there is no way how to implement this unless someone else makes a script to extract the pwd AND the pwd does not change, ever. Which would also make the set up harder for everyone.
2024-05-15:
See https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/551#issuecomment-2111341474
2024-05-18:
See https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/551#issuecomment-2118381739
2024-05-29:
See https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/551#issuecomment-2137323663
2024-06-25:
See https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/551#issuecomment-2189695781
2024-07-03:
See https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/551#issuecomment-2205580658
2024-07-16:
See https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/551#issuecomment-2230580891
2024-07-18:
See https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/551#issuecomment-2235950853
2024-07-20:
See https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/551#issuecomment-2241111249
2024-07-31:
See https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/551#issuecomment-2260750095
2024-08-12:
See https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/551#issuecomment-2283986721
2024-08-19:
See https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/551#issuecomment-2296393379
2024-09-16:
See https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/551#issuecomment-2353307429
2024-09-20:
See https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/issues/551#issuecomment-2363817573
MikeMM70
(Mike M.M.)
November 3, 2024, 4:05am
3
I made the mistake of upgrading the firmware when I set mine in, not realizing it would cause it to not work.
I can monitor the separate chime I got with my doorbell with another Tapo integration, but only it’s Wi-Fi strength and an overheat sensor. It’d be cool if I could trigger some of the chimes it has from HA as well for notifications, but that would be a separate integration and thread.
MikeMM70
(Mike M.M.)
December 3, 2024, 5:19pm
4
Great news, I just saw this on Github!
effcol
(Effie)
January 14, 2025, 8:50pm
5
Has anyone got this working again?
MikeMM70
(Mike M.M.)
February 8, 2025, 1:29am
6
Sort of…The Tapo video doorbell I got is rechargeable and as soon as I started playing with this integration the battery started draining much faster, so I’ve stopped for now.
It is just a switch in the app to enable it, though. “Third-Party Compatibility” under “Tapo Lab” in the “Me” section.
aldoushx
(Aldoushx)
February 15, 2025, 6:45pm
7
Hi, I would like to find a wireless doorbell which sends a signal to HA (or activates a switch/boolean) when the button is pressed. Is it possible with this doorbell in the Tapo integration ?
So, I just bought this doorbell. Have it hooked up, but there is zero support for video. You can control it, you can update it within Home Assistant, but you cannot actually view the camera footage in Home Assistant. Anyone else find this?
jchh
((not John))
June 8, 2025, 8:13pm
9
I have had the D230 for a while now. It’s great but HA can’t get video from devices via the doorbell/hub.
