Tapo D230 video stream in HA?
I’ve been trying to get my doorbell to show video in HA (or even still images would work) but can’t get it to work. I’ve followed the instructions here, managed to find the camera device ID using pytapo, set up go2rtc in HA and added the camera with the same URL as in the link.
When I try to view the stream I get the following error:
mse: streams: malformed HTTP status code “ERROR”
There’s not a lot of information about the D230 camera and HA out there, but if anyone has managed to get it working I’d love to know how.
Have you actually tried the standard integration that supports the D230?
Yes, of course. It provides a very limited set of options and no video or audio.
For future reference, this now works in v1.9.9 of go2rtc!
Hi @TexxK, would you be so kind and share more details how you managed to make this work? I am struggling with the same error message. I am kinda new to HA. I managed to make another Tapo camera to work by combination of “Tapo Camera Control” and “WebRTC Camera”. But here I am really lost. No clue how to properly format the url, no clue where and how to use the url (if constructed properly)… No clue how and where to get the child id by pytapo… Any help is appreciated!
Sure, keep in mind I’m not well versed in Python and got this after some trial and error. I’m sure there are better ways but this worked for me.
Started by downloading and installing Python on my PC and saved the following script to a Tapo.py file.
from pytapo import Tapo
ip = "[IP address to tapo hub]"
user = "admin" #don't change this
password = "[Tapo cloud password]"
tapo = Tapo(ip, user, password)
result = tapo.getChildDevices()
print(result)
Open a command prompt → cd to your script location → enter “python3 Tapo.py”. The child device ID you’re looking for is the first value called device_id, provided the doorbell is the only device you have connected to the hub.
Then, in go2rtc this is my config:
streams:
    doorbell: tapo://admin:[Tapo cloud password formatted as uppercase 256 hash]@[Tapo hub IP]/?deviceId=[device_id from pytapo]
When it comes to implementation I use it in 2 ways, in a WebRTC camera card and in a doorbell automation to get snapshots of the doorbell in my phone notifications. The WebRTC card defaults to the latest snapshot to save battery, however battery consumtion has increased since this started working so I’m not sure hiding the stream actually leaves the camera “asleep”.
Camera card:
type: custom:webrtc-camera
poster: /local/snapshot.jpg
streams:
  - url: ""
  - url: doorbell
ui: true
digital_ptz:
  touch_drag_pan: true
  touch_pinch_zoom: true
title: Dörrklocka
muted: true
style:
    .pictureinpicture { display: none; }
Automation:
alias: Ringklocka
description: ""
triggers:
  - trigger: state
    entity_id:
      - siren.tapo_hub
    to: "on"
actions:
  - action: camera.snapshot
      filename: /config/www/snapshot.jpg
      entity_id: camera.doorbell
  - delay:
      hours: 0
      minutes: 0
      seconds: 1
      milliseconds: 0
  - action: notify.mobile_app_pixel_8_pro
      message: Någon ringer på dörren
      title: Ringklocka 🔔
        ttl: 0
        priority: high
        notification_icon: mdi:doorbell-video
        channel: Ringklocka
        image: /local/snapshot.jpg
        actions:
          - action: URI
            title: Visa kamera
            uri: /dashboard-belysning/dorrklocka
          - action: UNLOCK
            title: Lås upp
mode: single
The unlock action then triggers a second “are you sure” notification and finally unlocks my front door.
Hope this helps.
Thanks a lot @TexxK ! This definitely helped a lot! I did some progress and now I am able to add a WebRTC camera card, that shows the stream from go2rtc. However I am not able to do a screenshot from the camera to have rich notification. May I ask you what exactly represents your “camera.doorbell” entity? And what integration you used to have such an entity? I use Tapo Camera Control, it provides me entities for the hub and for the doorbell as well, but most of them are settings. Visual editor or yaml do not show me any suitable device to take a screenshot except for other Tapo camera I have… I tried also deviceId (home assistant id) of doorbell and hub, nothing worked.
To add a camera entity go to Settings → Devices & Services → Add integration → Generic camera. My system is not in English so the actual menu items might be named differently.
In “source URL” add the go2rtc stream locally: rtsp://127.0.0.1:8554/doorbell
You are my hero :smiley: Thanks a lot TexxK!
I’m trying to add this camera and I’m just getting a black screen. This is the camera going via the H200 hub - the D230S1. In go2rtc I have:
streams:
    doorbell: tapo://cloud-password@[Tapo hub IP]/?deviceId=[device_id from pytapo]
I kept getting the unauthorised error with admin:SHA256password or admin:MD5password. Using the above config I just get a black screen. What options have you selected in the Tapo app or is there anything else I should look at?
Is there a reason why you havent looked at this? [Custom Component] Tapo: Cameras Control - Share your Projects! / Custom Integrations - Home Assistant Community
edit - sorry saw that you mention it above.
Hi @TexxK, Thanks for all the information, I’ve been able to setup my doorbell to get the camera integration working, I also had the snapshot automation working when I manually trigger the Tapo-Hub siren from the HA Device - Controls, but the problem I have is working out how the automation would trigger when the doorbell button is pressed? Does your automation correctly trigger from the doorbell button press? I’m not sure what I’m missing. TIA
@GeraldDuck I am glad you managed to integrate the doorbel as I did using TexxK’s guide. I am facing the same issue with the automation you described. I was not able to find an event for doorbell ringing. What we both hooked the automation to, is really manual trigger of siren, what is obviously different event than pushing the doorbel button… I am curious if this can be solved.
It very nice work-around I was able to setup in HA, now i see camera stream BUT cupule of problems
  1. Battery now draining like “crazy” :fearful:
  2. Tapo App i can still see it, however the Tapo Hub H200 is started becoming Offline every 2-3 days
  3. Doorbell Camera become Unavailable/Offline in my Google Home, Samsung Smartthings
The 1. yes i can understand but 2./3. WHY?! :exploding_head:
Anyone has similar XP? Maybe solution? :thinking:
Sorry I completely missed the updates in this thread. Unfortunately I was never able to find a trigger to the actual button press, and sometimes the hub siren did have a delay.
Eventually I installed a 12V transformer and swapped the camera for a Reolink D340. Much happier with this setup.
were you able to implement two way audio with go2rtc?
