Tapo H100 H200 T100 T110 T300 T310 T315 S200B S210 S220
Seems to be a capable (nice selection of different type devices), efficient (868 / 922 mhz) and well build (made by TP-link) platform, value seems to be decent too.
I could not find any information about progress in it being supported by Home Assistant, could be nice to have some progress?
i have a full set , thought they were compatible, but waiting on the intergration for it
I could not find any progress on Home Assistant platform
Should my initial post be in another category of the forum ?
I’m not sure what you’re looking for, but have you checked this out?
HomeAssistant-Tapo-Control
As I understand your link is for devices connected directly to internet via wifi / ethernet, devices aforementioned above require an extra device (hub) to connect to internet because of operating over sub-gigahertz frequencies.
Yeah, that’ll be it :slight_smile: carry on.
I could manage to add a Tapo Temperature/Humidity sensor (T315) through the Tapo H100 Hub only by integrating my SmartThings account to Home Assistant. Works perfect now.
The below Tapo Controller integration can only manage my Tapo smart plugs (P100 and P115)
I was not able to add in the Tapo Smart Button (S200B) to HA yet, but I don’t see if it would be useful under HA anyway.
[zee36)[Zoltan Gaspar] Please describe in more detail how you managed to get data into the HA from the T315
has anyone found a solution to include the S200B into HASS?
Has anyone found a way to have home assistant be able to read the sensor data from the Tapo T315? I can see the smart hub it connects to in my device list but it doesn’t show any of the connected devices, I seem to be able to only add Tapo devices that are directly connected to my network
I’m also interested in this integration and happy to help out if I can. I have a hub and door / motion sensors.
Does anyone knows where can I find an extra TAPO H200 smart Hub?
I also purchased the Smart Buttons because they are cool and having rotating capabilities opens many possibilities, but without HASS integration the best I could do was to make it work through an Alexa routine but its quite slow anyways… but no way to integrate them in HA yet :confused:
Hi, first step you should link your Tapo account to SmartThings , then install the SmartThings integration to HASS.
HASS will pick up all smart bulbs and plugs, together with the Tapo thermometer.
This is not working with the Tapo motion sensor unfortunately, I’m still looking for a way to try integrate this latter, or just simply looking for a different brand…
Hey. I’ve just bought the Tapo rv30 robot vacuum. Does anyone know how to integrate it with HA. I can’t get it to connect to the Tapo intergration.
Anyone managed to connect the H200 hub with the new version of Tapo integration (v2.10.1)?
It seems like you can now pair the TP-Link hub and control the S200. https://github.com/petretiandrea/home-assistant-tapo-p100/issues/354#issuecomment-1728949723
Just tried it, not working for me (managed to link H100 only)
I wish that I knew this before that I can’t connect S200 or Tapo devices with Zigbee.
I recently bought Sonoff USB and Tapo button thinking that these are generic setup and I can expand the echo system.
Is there any possibility to connect VIA sonoff dongle? Or a replacement button as I really liked Tapo price and usage.
Harry
I am trying to use the S220 double switch with a hub. I have the integration installed and can see and control various Tapo plugs, I can also see the hub and the S220 switch. However, the only entity I can see for the switch is the battery low binary_sensor.
I am running
Tapo integration 2.12.2
2023.12.3
Supervisor
2023.12.0
Operating System
11.2
Frontend
20231208.2
When I look in the code, it is possible that the S220 is not supported.
Any suggestions on where I have gone wrong.
