TAPO H200 HUB & TAPO T310 Temp & Humidity Sensor addition
Prior ensure the “SmartThing” integration is installed and you will require an API token from SmartThings
I was able to add my Tapo H200 Hub & Tapo Temp + Humidity Sensor T310 by carrying out the following:
  1. Using your phone with Smart things and connected to the same network
  2. Click add “+” then “add Device”
  3. Click “scan Nearby”
  4. Log into Web based “Smartthings” and ensure “Installed apps” is showing “Home Assistant”
As of 2024.12 the tplink integration supports the H200 hub.
