Tapo Stream Not Running from external
Hi, I’m using a Tapo C220 Cam in HA. The problem I’m working on since yesterday is:
If I move out of the local network and try to watch the stream from external, the stream crashes/freeze for me. Rtsp as well als webRTC, HLS, MSE, nothing works. Even the default Tapo Stream (HD) entity, does freeze. Any suggestions?
Sounds like a network bottleneck. If all above work fine when you are at home using a local ip that is.
