Hi I have H100 tapo tplink thing here. I want it to play a sound when my g4 door bell is pressed, i dont need it or want it to do anything else.
I have spent some time looking for instructions to get this added to HA some say use matter beta, some say use hacs, or some say install a tplink add on thing.
im wondering if the earlier installs were done the shitiest way then as time progressed people found better ways to add hardware.
anyway i dont use matter beta, im pretty sure ive been able to avoid hacs up to now. what is the simplest way to get this installed?
okay cheers, I’ve had a crack at it, the TP integration asks for the IP it takes an extremely long time to get to the next step, but it does get there. then it asks for the username and password. I cant get past this step error is: Connection error: try_connect_all failed
i cant see how any of these could mean make a chime sound. or is it just labelled stupidly like the ridiculous door bell “occupy” thing. i have deleted it and reinstalled it, still the same. did i buy the wrong unit? did it install badly?
Oh, i can select toggle state of led which does work.
sigh
Are you just trying to make it chime based on a button press of another device? I’m not too familiar with these but isn’t that just the siren? With an appropriate sound chosen using the select?
Hi @cue340 , can you please help me guide to the same workflow, do you get it to work? I want the same thing, get adicional chime for Aqara G4 when the button is pressed
