Tapping dashboard tabs accidently hits buttons
Hi all,
I have multiple tabs on my main dashboard, and all of them are too big for my mobile, so I have to scroll. But the buttons on top for the other tabs obviously have some transparency not only in view but also in control: if I hit any of those, it also hands through the tap action to the below.
Example: this is a part of my dashboard, scrolled down to a specific extend
As you can see, there are 2 identical mushroom buttons for my 2 garage doors, and above the dashboard sub pages. If I now tap any of those, be it the camera or the car one, it sometimes (not always but sometimes) hits also the garage door and it opens. In the end, I am to the dashboard I wanted, but the garage is open (and I even didn´t recognize it)
Is this something related to the theme maybe?
Am I the only one having this issue or is it a generally known one but everybody simply accepting it?
Maybe you have a z index set somewhere in mushroom, try removing it
Oh I was wrong, it´s a custom:button-card, sorry - but anyway, it does not matter what is in the background below the top menu items I tap. If a tap on those in the background causes any action without interaction, it will get hit sometimes. This above was one example only of many.
@VietNgoc is probably right. It should be because of a wrong set z-index in CSS. You can copy the yaml code from the dashboard and search in a text editor for “z-index:” BUT it can also be from your custom theme.
Try selecting the default one and see if it still overlaps. If yes search in the theme code for the wrong z-index, if not try another card like tile.
vscode finds this 356 times in 120 files, but not in dashboard nor theme yaml. So ?!?
Try another theme (also mind card or view theme if applied) or another card. I cant help you further without getting hands on your config.
Hi there,
Creator of the theme here. Can’t say I have ever experienced this on any of my devices. I also tried my best just now to replicate it and was not able to.
As far as a z index goes, this theme does not have that configured. Possibly this is something with card-mod or a custom card that you use? (if you use either of these)
What you might do is open the page in a web browser, then with dev tools use the “select element” tool to inspect the area you are having issues with.
e.g.
