Hello everybody!
I have an error message for a few weeks now, and can’t pinpoint it on any specific integration, so I could do something about it. The error is this:
Logger: homeassistant
Source: util/logging.py:207
First occurred: 13:05:22 (10 occurrences)
Last logged: 13:19:31
Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/util/logging.py", line 185, in coro_wrapper
return await target
TypeError: object NoneType can't be used in 'await' expression
File "/usr/src/homeassistant/homeassistant/util/logging.py", line 187, in coro_wrapper
log_exception(format_err, *args)
File "/usr/src/homeassistant/homeassistant/util/logging.py", line 115, in log_exception
friendly_msg = format_err(*args)
File "/usr/src/homeassistant/homeassistant/util/logging.py", line 207, in <lambda>
target.__name__,
AttributeError: 'NoneType' object has no attribute '__name__'
Does anybody have an idea to what integration this error message belongs? I have a feeling it could be “Spook”, but that’s only because it was the last “new” integration I activated.
I have searched for coro_wrapper
, but this doesn’t get me any further. Neither searching for __name__
Any ideas on how to start debugging this would be very much appreciated. I already thought about enabling debug for all integrations, but as this will likely need hours to read through all that logs, I thought I’ll ask first, if someone can push me into the right direction.
Thanks in advance!
