Hello
I use a printed_circuit_board_switch_2_channel
connected to a somfy module and wants to lower the awning.
Goal is:
- Channel 1 extends the awning
- if Channel 1 gets active, channel 2 gets inactive
- Channel gets inactive after 20 seconds (time to extend the awning)
- Channel 2 retracks the awning
- if Channel 2 gets active, channel 1 gets inactive
- Channel gets inactive after 20 seconds (time to retrack the awning)
Has someone coded this in the past ? Thank you for some hints!
Cheers
Laurent
Extend Awning
alias: Markise Ausfahren
description: ''
- platform: device
type: turned_on
device_id: ee07f7723bf142cc9524c26bba8d9ef7
entity_id: switch.printed_circuit_board_switch_2_channel1
domain: switch
condition: []
- type: turn_off
entity_id: switch.printed_circuit_board_switch_2_channel2
domain: switch
- wait_template: ''
timeout: '00:00:20'
continue_on_timeout: true
- type: turn_off
domain: switch
mode: single
Retract Awning
alias: Markise Einfahren
description: ''
- platform: device
type: turned_on
domain: switch
condition: []
- type: turn_off
domain: switch
- wait_template: ''
timeout: '00:00:20'
- type: turn_off
domain: switch
mode: single
![:grinning: :grinning:](https://community.home-assistant.io/images/emoji/twitter/grinning.png?v=9)
