Thanks for offering some guidance, but I’m not familiar with using GitHub and don’t really have the bandwidth to learn another source code control system at the moment. I was (perhaps naively) expecting the process of submitting an example to be a little simpler, but I do understand the reasoning behind it.
I have mocked up a valid RestAPICallExample.tsk.xml attached below with the description export blockquoted in case it is of use: .
RestAPICallExample.tsk.xml (1.6 KB)
RestAPICallExample (3)
A1: Variable Set [ Name:%url To:http://IPADDRESS:8123 Recurse Variables:Off Do Maths:Off Append:Off ]
A2: Variable Set [ Name:%path To:/api/services/script/turn_on Recurse Variables:Off Do Maths:Off Append:Off ]
A3: Variable Set [ Name:%entityname To:script.name_of_script Recurse Variables:Off Do Maths:Off Append:Off ]
A4: Variable Set [ Name:%token To:Bearer ABCDEFGHIJKLMNO Recurse Variables:Off Do Maths:Off Append:Off ]
A5: JavaScriptlet [ Code:var uri = url+path;
var data = {entity_id: entityname};
var xhttp = new XMLHttpRequest();
xhttp.open( “POST”, uri, false );
xhttp.setRequestHeader(‘Authorization’, token); xhttp.setRequestHeader(‘Content-Type’, ‘application/json’); xhttp.send(JSON.stringify(data));
var rtresponse = xhttp.response;
var rtcode = xhttp.status; Libraries: Auto Exit:On Timeout (Seconds):10 ]
