Tasker & Long Lived Access Tokens
You first need to ditch the ?api_password= portion if you’re trying to use a token. Second, I would give bokub’s post a read as that’s a fairly easy solution to get Tasker to work with tokens. Tutorial: Using the new Auth system with tasker
