adamjhodson
(Adam James Hodson)
February 6, 2019, 8:37am
1
Hi all,
I’ve got the tasker MQTT publisher plugin working perfectly when connected to my home network. However i access my HA via DuckDNS when outside of my network and i can’t figure out how to set up the Tasker plugin to allow for this if at all possible. I’ve currently got https://mydomain.duckdns.org and the port set to 1883 but the MQTT messages aren’t being received by HA. I’m using the Mosquitto add-on if this makes a difference.
Thanks all
adamjhodson
(Adam James Hodson)
February 11, 2019, 10:15am
2
Hi guys any help? Pulling my hair out here
Since I dont want to expose my Mosquitto instance (but instead expose my HAss instance to the outside world), I took another approach…
(I did that, because the Torque app does not support SSL connections and I want to upload my car logfile to HAss)
1)create a webhook automation
- id: 'mqtt_publish_webhook'
alias: Webhook MQTT Publish
initial_state: 'on'
- platform: webhook
webhook_id: <long_random_hash>
- data_template:
retain: true
topic: "{{trigger.json.topic }}"
payload: "{{trigger.json.payload}}"
service: mqtt.publish
As result, I can use Tasker’s built in HTTP POST to publish data.
P.S. I also use AutoTools to build a JSON string the lazy way…
Regards!
adamjhodson
(Adam James Hodson)
February 11, 2019, 11:09am
4
Thanks mate, I’m fairly new so alot of that doesn’t make sense at the minute but I’ll get reading and get it sorted. Thank you
Could you share how you managed to do this. I want to do the same thing but have no clue on how to acheive this.
Could you share your tasker profiles and tasks as well as HA config relative to this?
Thanks!
Sure. I can provide detailed infos when I’m back home…
