I am trying to get the tasker plugin to trigger an automation but whenever I do a test it tells me that there is a JSON error… Here is a screenshot of it:
Can someone tell me why this is wrong?
anyone? know the ansewr?
Screenshots only get you half way.
What if there is an encoding error or an invisible space?
Can you copy and paste that here?
Also, I guess many people have no idea of the Tasker integration you are using; heck I’ve been using Tasker forever and have no idea what is the task you’re using there. That means I can’t test it if you don’t post more information.
{"entity.id":"automation.calendar_alarm"}
Is what I’ve typed into the plugin. The plugin can be found here at: https://play.google.com/store/apps/details?id=com.markadamson.taskerplugin.homeassistant&hl=en
is there anything else I can supply?
So I downloaded it and did this:
And got this (as expected):
Just note that I did a “underscore” for entity_id and you did a “full stop” with entity.id
That seemed to do the trick… Thx
You’re welcome.
Hope you see the value in submitting a bit more information in your question. You increase the pool of people that may help!
