Since a few months, I can’t access the TasmoAdmin page from the Home Assistant interface.
It happens both when I connect via DuckDNS as well as when I access Home Assistant via the local IP address.
The TasmoAdmin icon is displayed in the menu bar on the left side, but when I click it I get a screen with the following message: myname.duckdns.org uses an unsupported protocol. (where myname shows my own name)
I see this both when I log on via DuckDNS as well as when I log on via the local IP address (where I would expect the interface has nothing to do with DuckDNS). The rest of the whole Home Assistant interface works flawlessly, both via DuckDNS as well as via the local IP address. It’s just TasmoAdmin that I can’t access.
I’ve looked for solutions for a while already, because there’s no way I can access the configuration page of my connected Tasmota devices. I’ve found similar complaints, but not how to solve it in Home Assistant (e.g. No 0.15.1 update with HA core-2021.10.0 - githubmemory).
My current installed version is 0.15.0. According to the Log, this is the latest and greatest:
Add-on version: 0.15.0
You are running the latest version of this add-on.
System: Home Assistant OS 6.6 (armv7 / raspberrypi4)
Home Assistant Core: 2021.10.6
Home Assistant Supervisor: 2021.10.8
The Tasmota devices are all working correctly, but I’m locked-out of the interface where I can configure them. So, it will become an issue for me.
I’ve uninstalled and re-installed the TasmoAdmin Add-On, bit with the exact same result…
Does anybody know if this is indeed still the latest and greatest? When Googling, it seems like a newer version should be available.
Does anybody know another thing that can cause me the be locked-out of the TasmoAdmin interface?
