G’day all,
Recently deployed some Xiaomi LYWSD03MMC BLE Temperature/Humidity sensors, using the ATC firmware. To receive the broadcasts I’m using a ESP32 running Tasmota 9.2.0. Tasmota receives and decodes all six thermometers, and they are viewable through the Tasmota web interface. Home Assistant in turn discovers the Tasmota, and some of the thermometers.
The issue is that upon rebooting the ESP32, only some of the thermometers are immediately available (depending on the broadcast interval). Whichever thermometers are available during the initial re/discovery are the only sensors which Home Assistant will mark as active and record sensor data for. Subsequently received thermometers never become available, despite the ESP32 receiving all six. Restarting the ESP32 will result in a different subset of sensors being available, however I have rarely had all six available together.
What is the mechanism Home Assistant uses to discover Tasmota and the attached sensors? Where is the issue likely to lie - with Tasmota or with Home Assistant?
