Tasmota Buttons as automation trigger
Hi everyone.
I am shifting from IOBroker to HA. I now stuck on a problem with my tasmota shutters.
I am using the tasmota-integration. HA allready registered the buttons as automation-triggers(with short_press, double_press and so on). Unfortunately if I configure a automation and push the button, the automation is not triggerd (i tried one press, two, long, different button).
I have no idea, what I did wrong. Maybe someone can help me here?
Tasmota config:
{“NAME”:“Shutter”,“GPIO”:[544,291,289,34,226,33,0,0,32,224,290,225,288,0],“FLAG”:0,“BASE”:18}
SetOption80 1
Shuttermode 1
Interlock ON
Shutterrelay1
SetOption73 1
SetOption114 1
ShutterButton1 3 - - - - 1 1 1 - 1 <— because I want to use button3, i also tried it with button 1 and 2
I also tried:
ShutterButton1 3 - - - - - - - - 1
Because the following Options are mentiond in the Tasmota-docs to have an effect:
SetOption1 0
SetOption11 0
SetOption13 0
best regards
Tobias
I have the solution. ShutterButton1 3 xxxxxxxxx was the problem.
In my case Tasmota published {“Shutter1”:{“Button3”:2}}. If ShutterButton1 3 is not defined, it publishs {“Button3”:{“Action”:“DOUBLE”}} and now it works.
Can be closed.
