I have set up two relays, a wemos with tasmota and a hard wire motor for automated roller blinds. I have installed the first motor/blind and it works great via the tasmota interface and on my home assistant dashboard. I add a WiFi tuya switch flashed with tasmota and set up an automation to toggle the blinds up/down using the call service - cover:toggle actions. My issue is that the automation when called sends a “shutterclose1” command and not a “shuttertoggle1” command as it should. Any suggestions? Thanks
Anybody? In the developer tools I tested the call service:toggle and it sends a stop signal in the tasmota console. Is this a home assistant issue or a tasmota issue?
