I’m trying to setup a Tasmota dimmer manually in my switches.yaml file. All of my regular switches are working fine, but I’m getting an error when I try to setup a dimmer.
My switches.yaml code is below. I’m getting an error stating that the brightness_command_topic is an invalid option, in fact it doesn’t like any of the brightness commands. When I check the switch.mqtt instructions, there is no specific brightness topics (I got this code from digiblur). Can someone help me with the right way to setup a dimmer?
Error:
Invalid config for [switch.mqtt]: [brightness_command_topic] is an invalid option for [switch.mqtt]. Check: switch.mqtt->brightness_command_topic.
Switches.yaml code:
- platform: mqtt
state_topic: "stat/tasmota140/RESULT"
value_template: "{{ value_json.POWER }}"
command_topic: "cmnd/tasmota140/POWER"
availability_topic: "tele/tasmota140/LWT"
brightness_command_topic: "cmnd/tasmota140/Dimmer"
brightness_state_topic: "stat/tasmota140/RESULT"
brightness_scale: 100
on_command_type: "brightness"
brightness_value_template: "{{ value_json.Dimmer }}"
qos: 1
payload_on: "ON"
payload_off: "OFF"
payload_available: "Online"
payload_not_available: "Offline"
