Tasmota dimmer not publishing brightness to MQTT
I have the Tosmota preflashed dimmer from Martin Jerry
all is working well except the brightness will not publish to MQTT when adjusting it from the switch itself
I want to use this ‘Dimmer’ value in NR to sync some other lights in the house but it wont publish the value. If I change the dimmer inside HA it publishes it fine
