Tasmota Dimmer Range
Hello
When I look at the console output in Tasmota, I see a low dimmer Range of 13 and a high of 97. I then run the command “dimmerrange 13,97” without the quotation marks. I’ve installed a light custom card that can control the light and dimmer function.
Issue
Increasing the light card dimmer function doesn’t bring the light to its full brightness. I have to manually increase the brightness at the wall switch. Any ideas on how I can correct this?
Unfortunately I didn’t check the console output when using the light entity card.
Thanks in advance for any help that can be provided.
