myle
(StePhan McKillen (Other kiwi Here))
April 15, 2021, 5:54am
1
After watching
found on of these in the draw
put tasmota on it
did a so115 1
and bugger I can see my BLE Xiaomi Mijia LCD Digital Thermometer
on the main tasmota main screen I see
so I jump into the Console I see
looking at the
tele/tasmota_32/SENSOR
i see
{"Time":"2021-04-15T06:42:32","MJ_HT_V1359039":{"mac":"582d34359039","Temperature":19.3,"Humidity":69.4,"DewPoint":13.5,"Battery":100,"RSSI":-81},"MJ_HT_V1ded5fd":{"mac":"4c65a8ded5fd","Temperature":19.9,"Humidity":69.6,"DewPoint":14.2,"Battery":100,"RSSI":-92}}
with MQTT I can read this
- platform: mqtt
name: "BLE temperature"
state_topic: "tele/tasmota_32/SENSOR"
value_template: "{{value_json['MJ_HT_V1359039'].Temperature }}"
unit_of_measurement: "°C"
after a restart
if I want the DewPoint I just change it to DewPoint
- platform: mqtt
name: "BLE DewPoint"
value_template: "{{value_json['MJ_HT_V1359039'].DewPoint }}"
Done
wapst
(Stefan Wapplitz)
March 13, 2023, 7:14pm
3
Hey,
könntest du das einmal etwas genauer erklären, wie ich das im HA einrichten muss?
Vielen Dank.
Gruß Stefan
myle
March 13, 2023, 8:09pm
4
English please
but what part do you want little more about
MQTT YAML has change
- platform: mqtt
comes
in you config file. Well like mine in there own files
so I have
mqtt:
sensor: !include_dir_merge_list mqtt/sensor/
climate: !include_dir_merge_list mqtt/climate/
binary_sensor: !include_dir_merge_list mqtt/binary_sensor/
switch: !include_dir_merge_list mqtt/switch/
light: !include_dir_merge_list mqtt/light/
then inside each folder you can add the yaml file
but after typing all of above
there a other way
by adding a Bluetooth dongle and HA will find them for you and add them for you
wapst
(Stefan Wapplitz)
March 14, 2023, 5:12am
5
Please excuse.
Unfortunately, the PC is in the basement, so I did it with an ESP32. So I have to read out the values via the mqtt yaml, do I understand that correctly? I am using Home Assistant on Ubuntu.
Best regards
Stefan
